Need help finding JMP-1 transformer
jamminpete
my favorite amplifier: JCM 800
Post by jamminpete »
Hello
Anyone have a source for a transformer for a JMP-1 preamp?
I may have to rebuild if I cannot find. In case I need to rebuild, anyone know what the HT voltage is supposed to be? Based on schematic the LT secondary appears to be 12V then there is a 15V center tapped also but it doesn't say what the HT secondary voltage is.
Any info would be appreciated.
transformer
transformer
board
board
transformer wiring
transformer wiring
You could try contacting the manufacturer and ask them about it.
http://www.dagnall.co.uk/about/contact.html
It's a model TXMA-00014...
EDIT: elsewhere on their website they say they specifically don't sell spares for Marshall products and to contact Marshall about it, but perhaps they'd still be willing to at least share the specs with you.
Marshall's website now says they don't sell any spares to "the general public".
Jmpj48
Post by Jmpj48 »
Jmpj48
Post by Jmpj48 »
There transformers are kinda expensive. But they are top notch I had to replace my transformer in my ada mp1 got it from mercury magnetics.This is the only place I have found that makes there on transformers.
jamminpete
Thanks. I'm going to try to rewind it. The LT side is still good.
Groovenut
Has thanked: 60 times
Been thanked: 100 times
Post by Groovenut »
Given that the caps in the HT power supply are rated at 350V, I would guess they are running the filtered DC to the plate resistors at around 300 volts. Most Marshall preamps run this voltage between 245 and 350 volts, so it seems in the ball park.
okgb
Has thanked: 222 times
Been thanked: 38 times
Post by okgb »
It seems a problem with those preamps that the transformers emit a fairly loud " acoustical " hum when they on, so you could do better!
jamminpete
I bought a new old stock from The Guitar Store on Reverb. He had one more for sale last time i checked in case anyone wants one. From the Netherlands and arrived in US within 4 days.
In case anyone wants to know the HT voltage is about 220VAC. When the amp is loaded down it drops to about 205VAC.
Its still not fixed though I am having other issues the -15V regulator is only outputting = -2V and there is nothing on the display.
Does not pass a signal either. Tubes have been tested good.
jamminpete
Replaced the 7915 regulator and everything powered on correctly. Then I was getting screeching noises on all the patches.
Did a factory reset: (Hold OD1+Clean1 then power the unit) and now it all works properly.
