Gutshots: Again, I went and whipped up a schematic: As you may remember from the Tube Overdrive topic, again the tube is heated directly with 18V... And this time, I suppose that the tube CAN provide some distortion, especially when you crank the Volume and Drive knob. This time LEDs were used as clipping diodes and there is no hard-clipping, so the levels on the tube input might get high enough.
Also, that is one interesting tone section. It looks like two low pass filters, and when the tone knob is turned all the way up the response is flat.
As always - all corrections, questions and suggestions are more than welcome
