Mojo Hand FX - DMBL [traced]
- lead2203
Says in the description that it is like the real circuit found in the amp !?!? I didn't know the Dumble amp circuit was a hi voltage tube screamergght wrote: ↑07 Jun 2020, 06:18 Gut shot. Upper right looks like diode and transistor feed back loop??
https://toy-love.hatenablog.com/entry/2 ... 1397135083
- DjPsychic
Was looking for threads on this pedal and forgot I started this thread
Maybe it's a Zen? It seems to have a similar amount of components, and the three diodes...
a layout/schematic of this would be awesome. I'd probably get rid of the middle selector switch and set it to whatever the "down" position is...
- DjPsychic
- Intripped
well, we could try and trace it, anyway.
caps values will ramain uncertain, unless you dare, and desolder and measure them (or if we find other pics of the through-hole version, with visible values).
what's under the second PCB with the pots?
i can see what looks like a charge pump, in this SMD version, in the bottom-left corner of the bigger PCB
- DjPsychic
I just saw this response sorry!Intripped wrote: ↑27 Sep 2021, 13:36 well, we could try and trace it, anyway.
I have since sold the DMBL and built a Z-Drive
If a non-SMD version comes up for sale I'll grab one and we can trace.
