Danelectro - 9100 Tube Reverb Box  [schematic]
I know, if you're going to build a reverb unit, at least build the Fender, ... or just don't use cardboard
...but still, for reference sake and mostly because you could still fall into the trap of paying 15USD for this pdf... here it is
danelectro_reverb_box_9100_sch.pdf
(287.23 KiB) Downloaded 165 times
okgb
Has thanked: 222 times
Been thanked: 38 times
Post by okgb »
Curious [ or cheap ] they don't use a transformer to drive the spring like fender does, so it'd be a little easier to throw together
I'm still not tempted.
The one in the pics has a reverb driver transformer added! Also has an obviously non-original tank. Appears that one has likely been modded quite a bit.
okgb
Post by okgb »
Yeah , or it didn't really work [ well ] until they did that !
