Biyang Tonefancier Blue BL-8  [schematic]
blue4me
Post by blue4me »
I really like this pedal. I’ll work on a schematic in a bit but here’s pics for now. I’m wondering what it’s derived from.
It’s very warm (no treble), has loose bottom, very smooth, a ton of output. Only thing I could see wrong with it was some nuts were loose.
Renegadrian
Has thanked: 15 times
Been thanked: 15 times
Post by Renegadrian »
Did you manage to work the schem out!? it seems a little but funny circuit...curious to read it!
EddieTavares
my favorite amplifier: marshall
Been thanked: 25 times
Post by EddieTavares »
It looks like a proco rat without the output buffer and leds instead a diodes, it's easy to implement a tone control.
CheapPedalCollector
Has thanked: 432 times
Been thanked: 141 times
Post by CheapPedalCollector »
I was about to say yeah, it looks like a RAT.
Manfred
Has thanked: 1597 times
Been thanked: 1300 times
Post by Manfred »
I made this PCB clone for tracing, can you please put the component values in the picture with the components.
Renegadrian
Right! Just got one today for cheap, man let me say it's one of the worst pedal I've ever played! it can get some use with just a zic of gain, turn it up and you get lifeless mud sound...
Renegadrian
UPDATED!
Manfred
Post by Manfred »
This pedal is similar to the FAME Slasher DS-10, so I just had to edit its schematic.
viewtopic.php?f=1&t=30326&p=278466&hili ... er#p278466
Can you please measure the values of the potentiometers and the resistors?
Renegadrian
gain is b100k and volume is b10k
Manfred
Post by Manfred »
Renegadrian wrote: 30 Dec 2020, 23:52 gain is b100k and volume is b10k
Thanks, are the resistance values correct, have you already checked them?
Renegadrian
Did you read my previous post!?
Manfred
Post by Manfred »
Renegadrian wrote: 31 Dec 2020, 07:57 Did you read my previous post!?
Yes I did, you wrote in the previous post:
Got a problem with 1/8 metal resistors, quite difficult to read for me, guess it will be easy for others to complete the schem.
I think we are talking at cross purposes, did you measure values of resistors to confirm them?
Renegadrian
Right, I wouldn't read those damn resistors, I just measured with MM.
The previous image I uploaded has been updated.
Guess I'll transform it into a grey dod 250, it should be quite easy.
Manfred
Post by Manfred »
Renegadrian wrote: 31 Dec 2020, 14:53 Right, I wouldn't read those damn resistors, I just measured with MM.
Thanks a lot!
Manfred
Post by Manfred »
Here the verified layout and the verified circuit diagram.
CheapPedalCollector
Super easy to add a tone control to that and make it into an overdrive with a couple 100k pots.
Renegadrian
small correction on the schem, gain is 100k linear not log. please change accordingly.
Manfred
Post by Manfred »
Renegadrian wrote: 01 Jan 2021, 01:26 small correction on the schem, gain is 100k linear not log. please change accordingly.
The potentiometer type I have changed circuit diagram above.
xfree
Post by xfree »
I want to mod this with a tone knob, i find it too wooly at times on high gain....but perfect tone on the low gain
Pedal peddler
wildschwein
Post by wildschwein »
Love this pedal -- huge thick tone with good sustain. Great with single coils.
