REAGUN DISTORTION traced
Manfred
Has thanked: 1597 times
Been thanked: 1300 times
Post by Manfred »
While cleaning up I found this incomplete Reagun Distortion that I bought years ago.
Anyway, now I have traced it.
Here the PCB layout and the schematic, some measurements come later.
This is the same PCB as the REAGUN Overdrive but partly with other, omitted and additional components
Ready to print PDF-Files:
ReagunDistortionPCB_componentSide.pdf
(27.12 KiB) Downloaded 80 times
ReagunDistortionPCB_SolderSide.pdf
(16.08 KiB) Downloaded 83 times
SprintLayout 6.0 File:
Reagun Distortion.zip
(42.68 KiB) Downloaded 90 times
Manfred
Post by Manfred »
Ups! I forgot the pictures in my last post.
Manfred
Post by Manfred »
During the repair I found an error in the schematic, the resistance between terminal 5 of the OP-amp and the 4.5 volt point has a value of 470 Kiloohm and not 22 Kiloohm.
george giblet
Has thanked: 180 times
Been thanked: 272 times
Post by george giblet »
The 10n on the switch probably connects to the 1k and ground. The 2x220p connects to the 1k + 10n + 1M point.
Manfred
Post by Manfred »
Hi George,
Thanks for looking closely you are right.
mirosol
my favorite amplifier: Been on Bogner for quite some time now.
Completed builds: Over 1000 and counting.
Has thanked: 190 times
Been thanked: 446 times
Post by mirosol »
And a stripboard layout for this one too.
+m
http://tagboardeffects.blogspot.com/
http://mirosol.kapsi.fi/
"No such thing as innocence" -Iron Chic
