Page 5 of 8
Re: Suhr Reactive Load
Posted: 28 Jan 2021, 10:43
by evh0u812
Looks great. You might want to remove that bolt holding the inductor down and replace it with plastic cable ties. If it's not stainless the inductance won't be accurate.
Posted: 28 Jan 2021, 12:04
by acco
@evh0u812 thanks a lot, I hadn't really thought about it I will follow your advice
Posted: 29 Jan 2021, 09:37
by floris
Or use a nylon bolt.
Posted: 29 Jan 2021, 12:10
by floris
I see two problems in this build, if I see it correctly:
1) Why is there a connection between the 68 Ohm resistor and one side of the output transformer? The output transformer needs to be connected to earth there. The 68 Ohm resistor (parallel to the 0.6mH coil and the 22nF cap) should not be connected to earth.
2) Why is the other side of the output transformer connected to the 47k Ohm resistor? The 10k Ohm line out volume pot needs to be connected in between so it forms a voltage divider with the 47k Ohm resistor.
Where will you put the capacitor(s) (3x 80uF in parallel = 240uF) that go parallel to the big 6mH inductance?
Are the power resistors mounted off board on a heat sink?
Posted: 29 Jan 2021, 16:36
by acco
thanks friend,the number 1 is an error I'll fix it as soon
, the 47k is also wrong
yes the power resistors are on the heatsink and the capacitors will go in their place when they arrive. THANKS for the corrections I will post photos during the next phase of the work.
Posted: 29 Jan 2021, 16:46
by floris
Yes the 47k is in series with the 10k pot. But the WIPER of the 10k pot needs to be connected to the output transformer. The 47k resistor should not be directly connected to the output transformer. Please check again because it looks like it is not connected correctly.
edit: Oh it looks like you see this problem...
Posted: 29 Jan 2021, 16:54
by floris
And don't forget to connect the "68 Ohm resistor // 0.6mH coil // 22nF cap" in series with the "3x80 uF capacitors // 6mH coil".
Posted: 16 Feb 2021, 14:10
by m0rk
Guys, I wanna try and build a very simple reactive load box based on this Suhr design, I edited the schematic traced by soulsonic, omitted everything that I won't be needing and I just need someone with more experience than me to confirm that I did not go too far with it
Also I will be replacing the big 7 Ohm power resistors with 8 Ohm values, since I have them from a previous project (a simple dummy load box). Is this of any concern?
Please!
Posted: 16 Feb 2021, 18:34
by floris
You need the Line Out! But you can leave out the balanced output if your have a DI box or some sort of transformer isolator, unless ground loops are not a problem for you.
The 8 Ohm resistors will be fine.
Posted: 16 Feb 2021, 21:45
by m0rk
Thanks for your reply!
My amp has a built-in direct output socket, it's a Mesa Boogie Mark III, so I only want to replace the speaker with this reactive load, for silent recording.
Posted: 17 Feb 2021, 03:43
by Optical
The mark III output isnt isolated (just a divider on the output), so you might have ground loop issues.
But you can add the line transformer isolator easily to resolve
I also have a Mark II (green stripe), great amps
Posted: 17 Feb 2021, 07:46
by m0rk
Mine is a purple stripe. Yep, great amp, totally love it!
And no, I don't get any ground loop issues on the direct output with my speaker plugged, so I hope I should be ok with this simple design.
Posted: 17 Feb 2021, 15:09
by floris
Ah right your amp already has a Line Out from the speaker output, you'll be fine.
Posted: 17 Feb 2021, 15:41
by m0rk
ok then, thank you guys, I'm like a total beginner and I really needed to run this by someone pro.
Posted: 18 Feb 2021, 04:40
by soulsonic
Be sure to use a big heatsink so you don't need a fan!
Posted: 18 Feb 2021, 17:29
by m0rk
sure thing! by the way, thanks for sharing this, much appreciated!
never would have thought that a small box with a few electronic components could cost almost 500 euros here in Europe...
Posted: 20 Feb 2021, 02:40
by xbearxau
Id really recomend fitting the line out. Its only a couple of parts and I promise you one day you will want to use this with another amp.
Posted: 20 Feb 2021, 08:15
by m0rk
when that day comes I hope I will have enough knowledge to build something new and more complex, of my own design maybe
Posted: 16 Mar 2021, 15:47
by AndrewGallios
xbearxau wrote: ↑20 Feb 2021, 02:40
why your previous posts have been deleted?
Posted: 17 Mar 2021, 09:54
by m0rk
dude was posting some of his own designs, some cool stuff, probably decided to monetize them somehow and took them down from this board.
