I honestly haven't decided if I want to make my own included power amp or just run it as a preamp yet.
As for what the switches do, they're all kinds of voicing switches, such as bright switches, crunch switches, coupling/filter caps, etc...
Cathode bypass switches are definitely planned for at least some stages, but also cathode resistor shorts (may have up to 3 resistors on some stages and bypass some via shorting on a switch). I'm guessing it's the same as the caps since its they're parallel so that's good to hear.
But I would also like them to perform similar bypasses in the signal path on coupling capacitors (always with one in line still) to control the voicing more, as well as plate-power and grid-gnd resistors.
So right now my assumption is this:
As far as over-voltage/ampage, almost any switch will be fine. Maybe one exception is at the plate to voltage? But I suppose I could probably get most or all of this effect by just having more switches on the cathode.
But popping could be bad on a loud amp. So for anything that can be assumed will be messed with when the volume/gain up, generic physical switches could be an issue for pops.
I've been confused about LDR switching a little bit - LDR switching is where you use the photoresistor to control a relay for the switching, isn't it? Why not just use a relay? And what do you really gain by controlling the relay with a transistor rather than just straight from power? These questions have alluded me on the relevant resources I've been able to find...
If I'm not making sense, I've attached a copy of the schematic so far, though its a mess and I want to say most of those switches are probably going to be removed as well as maybe some later stages. My idea came from heavy switching amps but also from the Carvin Quad X (11 stages in one channel, 8 preamp tubes), but wanted to include architecture from the Peavey 5150/SLO and something more classic (Univox 1086). And so I basically put everything I saw as a choice the designer took for the voicing specifically and turned it into a switch for now to see how many it could possibly be at max and I'll make it reasonable from there. Maybe put the Quad X stages somewhere more in the middle but maybe that should be a switch too...
So sounds like most of this would be technically safe with DIP switches, though I know they may not last the longest. Maybe socketting them all would be a good idea. Also maybe not buying these switches from Tayda for once. DIP switches would just be perfect because they're so small, seems like the closest analog equivalent to the level of control a micro-controller can provide.
Thank you all!
EDIT: Attachment failed probably due to my resolution. Uploaded to
Imgur
