EHX - Nano Chorus
tunghaichuan
Post by tunghaichuan »
Got one of these cheap at Guitar Center, didn't try it out first which was a mistake. It is very noisy when turned on. Lots of white noise. The chorus sound is pretty good, but the noise kind of ruins it for me. At first I thought it was broken, but tech support at EH said that the noise floor is higher in this pedal than their other ones.
Anybody have a schematic for it? Or advice on how to quiet it down?
TIA
tung
Obligatory gut shots:
toneman
my favorite amplifier: anything that works
Completed builds: meatolation, wobolation, ringolation clones, PAiA synths/modulars, dipthonizer clone, MOTM modules, pedal mods and repairs
Has thanked: 178 times
Been thanked: 45 times
Post by toneman »
add a preamp at the front??
just a thought thunk while thinkin'
8)
Tone-to-the-Bone
BJF
Been thanked: 68 times
Post by BJF »
I have one of these and it's a nice sounding unit allthough not as enchanting as the Small Clone but the Nano dropped the level when engaged.
I replaced a resistor sitting at the mixer amplifier to raise output to unity.
It should be pretty easy to find, close to the footswitch I seem to remember but anyway simple to find and that makes the unit a whole lot more useful.
Have fun
BJ
wwatersteve
Post by wwatersteve »
Anyone ever figure this one out? I have this pedal and the noise is huge, but if I can dial it down i would love this pedal.
gena_p1
Has thanked: 23 times
Been thanked: 11 times
Post by gena_p1 »
Just build baja small clone, and have a fun
The G
Grease Monkey
Has thanked: 407 times
Been thanked: 282 times
Post by The G »
Hi folks,
I just bought a defective Nano Clone. I was for less than 12 euros, so I figured that even if I could not make it work, the parts would make up to the price paid.
Long story short, I took my time to trace the schematic. I have no way or desire to measure capacitors in-circuit (even less SMD capacitors). And there WILL be mistakes in my tracing. I think that this may be of some use to someone, though.
I fixed it (the problem was with the LFO - R15, I just resoldered it) and I would mod it (adding Depth and Blend controls as in attached schematic). But it is SMD based, it has positive ground (WTF, EHX?) and I already had everything for another chorus to be made from scratch, so I think I'll just resell it.
Back to topic:
1. for the volume drop decrease R25 or even better make a Blend control as in the attached mods
2. for the noise decrease first the chorused signal level (TRIM2) to your taste and see if it is still too much. I would check if taking out TRIM2 makes a difference. Also, mess with C12, C19-R28 and C21 to let less highs through.
I made a test with an LM358 based LFO using the same circuit as in the Nano Clone and an 100k pot as Depth control. It did sound better to my ears.
nano_clone_1.sch
Eagle CAD schematic
(78.71 KiB) Downloaded 585 times
thanks for all of your hard work, not an easy job at all. I hope I don't sound unnappreciative, but would you posting a notice on your schematic that it is unverified and may contain errors? this kind of thing can foul up further tracing when bad schematics get passed around the net. great second post, and thanks again for sharing!
The G
Grease Monkey
Post by The G »
RnFR wrote:thanks for all of your hard work, not an easy job at all. I hope I don't sound unnappreciative, but would you posting a notice on your schematic that it is unverified and may contain errors? this kind of thing can foul up further tracing when bad schematics get passed around the net. great second post, and thanks again for sharing!
Sorry, I thought that since this is not a very loved pedal, nobody would use my tracing other than for troubleshooting. So I placed a warning in my post only.
I attached new schematics with warning included. Please delete the ones from the first post.
Best regards!
traced schematic - incomplete, unverified and may contain errors
mods to traced schematic (which is incomplete, unverified and may contain errors)
The G
Grease Monkey
Post by The G »
Nevermind, I just discovered I can delete attachments. Maybe, unknown to me, there is also a way to edit old posts :scratch: .
grrrunge
Completed builds: Loads!
Has thanked: 50 times
Been thanked: 203 times
Post by grrrunge »
Bought one of these yesterday thinking "how bad could it be?" at around $60 i just took it home and tried it... I shouldn't have! I'm returning it today!
Too much hiss :slap: it's embarrasing for EHX that they wil actually produce such a crappy unit! I liked the chorus below the hiss though - i'm gonna try the neo clone today, though it's $20 more :roll:
Fender3D
Has thanked: 120 times
Been thanked: 150 times
Post by Fender3D »
Whether the attached schematic is right, EH should have built 2 LP filters with those 2 PNPs (just like in small clone) to get a lower noise...
if you lift R12 and R23 you may add an RC cell to tame noise down.
R12/C10 maybe provide a small regeneration (like in flanger)?
I wonder what it sounds like without...
Fender3D
Post by Fender3D »
Just noticed:
The 470uF electro is named Stone...
wernic1
Post by wernic1 »
Here's my pedal with a Depth control.
Marky-M
Post by Marky-M »
just found this topic and i am very interested in trying to fix the level and hiss problem, since i like to fix stuff.
I'm just a hobbyst with a very limited knowledge but very patient and haven't tried SMD soldering jet but i will give it a go since i got this pedal.
BJF wrote:Hi,
Have fun
BJ
BJ, do you remeber which resistor was it excatly??
Did you mean R36 that is phisicaly close to the footswitch or you meant on the schematic?
thx!!
