Laney Black Country Customs Tony Iommi Signature Boost Pedal
- jhergonz
Hi Bugg, may i know what is the size of the pcb holes for the toggle switch did you use?bugg wrote: ↑20 Nov 2020, 13:02 The schematic has been verified, I'll get it posted as soon as possible.
https://www.pedalpcb.com/product/pcb357/
- bugg
The holes are 0.05" x 0.1", the annular rings are 0.1" x 0.15".
PedalPCB.com - http://www.pedalpcb.com/
- andregarcia57
thanks!
- jhergonz
- andregarcia57
hello guys, is any schematic available?
- rmroza
not that I'm aware of, but Buggs had a blast of a bunch of things posted recently, soo will be working on all of the documentation, which will include the schematics between now and the end of the year over the holidays!
- andregarcia57
- Ichabod_Crane
Here's the document:
https://www.pedalpcb.com/docs/DarkEsbat-PedalPCB.pdf
And here a still unverified veroboard layout:
https://dirtboxlayouts.blogspot.com/202 ... boost.html
It's a Sallen-Key filter. A 2 pole filter that in this case is acting as a low pass. Then can be set to be unity or amplify. The op-amp big muff has one that's set up has an amplifying low pass filter.
- andregarcia57
Ichabod_Crane wrote: ↑12 Feb 2021, 09:24 Here's the document:
thanks for the tagoboard!
is it checked? someone set up?
thanks
- Ichabod_Crane
If you click on the URL link you can see that is verified, now.
- andregarcia57
Great boost /od - TL072p
Well, I just found out it is pretty much the same as the TC Electronics Spark Booster...
