Orange - Terror Stamp  [traced]
J0K3RX
Has thanked: 315 times
Been thanked: 555 times
Post by J0K3RX »
I picked this up for almost nuthin so, I figured I would do the right thing, bust it open and get some pictures for all the pedal junkies here at FSB... I will try to trace it as I get time but, don't hold your breath... If somebody wants to have a go at it from the pics that's fine with me! If needed I can answer any questions you may have, get some better pics, part values, voltages etc..
This is a cool little box, loud as hell for the size and it's about as heavy as a paper clip!! Sounds damn good also but, it needs a little kick in the nuts from an overdrive to get it chuggin good... and it takes overdrives extremely well! I like it alot actually and it's quite amazing! The poweramp is a TDA7379 which is stereo quad or stereo bridged configurations and it's actually capable of 38 Watts!! That may explain why it's so loud :hmmm: The tube is a 12AX7 and it's operating at low voltage...
Pics at the link below
https://www.dropbox.com/sh/5rwpqk9hglxv ... MSR0a?dl=0
culturejam
Has thanked: 432 times
Been thanked: 562 times
Post by culturejam »
It's a pretty cool concept. Looking forward to see how they put it all together.
J0K3RX
Post by J0K3RX »
Off subject... Just found out that Eddie Van Halen died.. F%$K 2020!!! Worst year probably ever!!!
tonyharker
Been thanked: 14 times
Post by tonyharker »
What sort of heatsink is on that TDA7379 I wonder.
plush
Has thanked: 35 times
Been thanked: 160 times
Post by plush »
tonyharker wrote: 07 Oct 2020, 10:47 What sort of heatsink is on that TDA7379 I wonder.
I bet it's just screwed to the enclosure.
J0K3RX
Post by J0K3RX »
Looks kinda like this.. actually, it looks exactly like this.
J0K3RX
Post by J0K3RX »
When I get a chance I will remove the tube and peel the black protective tape off so we can see the traces hiding underneath..
tonyharker
I'd like to know how you picked it up for for almost nuthin :)
J0K3RX
Post by J0K3RX »
tonyharker wrote: 07 Oct 2020, 15:00 I'd like to know how you picked it up for for almost nuthin :)
Somebody realized that it was just sitting in a box not getting any attention and it was going to continue sitting in a box so... I stole it for $50.
I was just eyeballin this and comparing it to the Micro Terror :hmmm: Looks very similar...
Saruman
Been thanked: 145 times
Post by Saruman »
It is very interesting to get the scheme! I will follow the topic.
J0K3RX, I will ask you to see how the power supply voltage for TDA7379 is made. Stabilizer, or directly from the 15 volt power supply?
Why TDA7379 (4 channels) if there is TDA7279 (2 channels)? Thanks!
Saruman
Post by Saruman »
Hello everybody! Is there any news on this device?
I am interested schematic of part with TDA7379.
J0K3RX
Post by J0K3RX »
Saruman wrote: 10 Jun 2021, 15:56 Hello everybody! Is there any news on this device?
It's basically the same as the Micro Terror which uses the STA540.. The TDA7379 and STA540 are identicall as far as I can tell. Looks like it's running in the double bridge configuration using only the left side.
uterror.pdf
(77.74 KiB) Downloaded 356 times
deltafred
Has thanked: 808 times
Been thanked: 299 times
Post by deltafred »
With the Micro Terror schematic there is something odd going on around R24 and R25, R24 is shorted out.
J0K3RX
Post by J0K3RX »
deltafred wrote: 10 Jun 2021, 21:01 With the Micro Terror schematic there is something odd going on around R24 and R25, R24 is shorted out.
Good Catch.. Not my schematic
From eyerballing the pics of the board "I think" this is correct.
Image 1.jpg (11.87 KiB) Viewed 4355 times
Saruman
Post by Saruman »
Thanks, guys! That's great! I was only interested in the power amplifier in this device.
J0K3RX
Post by J0K3RX »
Saruman wrote: 11 Jun 2021, 13:56 Thanks, guys! That's great! I was only interested in the power amplifier in this device.
Sparkfun has a kit.. The heatsink is stupid tall and it's kinda pricey...
https://www.sparkfun.com/products/9612
Juarocks
my favorite amplifier: Anything Marshall
Post by Juarocks »
Hi guys, i've been looking for gut shots to try and trace the Micro Dark and,
judging by this video
and these 2 images
i came to the conclusion that both these amps are the same thing except for the extra volume on the Stamp.
There are 5 op amps in both the Dark and Stamp, and only 3 in the Micro Terror and they sound very different. And the Micro Dark is made with THT components only, wich would make it easier to figure out capacitor values.
So, if anyone has access to a Micro Dark and could post some pics of it i think that could kill two birds :wink: :applause:
bmxguitarsbmx
Has thanked: 657 times
Been thanked: 203 times
Post by bmxguitarsbmx »
the VR1a Gain control looks suspect as well on the uTerror schematic
Juarocks
Post by Juarocks »
Been tracing the Stamp, this is what i have so far:
not sure about C58 placement or whats below U2
i need more detail in this area front and back, plz :D
