Where to get 9mm PCB mount switches?
BurgerCrisis
Post by BurgerCrisis »
Where do you get PCB mount switches that can mount flush alongside 9mm pots on the same board?
peterc
Has thanked: 68 times
Post by peterc »
Not sure where you are, try mouser.com and search for sub mini toggle switch. The PCB mount examples stand about 9mm high off the PCB.
plush
Has thanked: 35 times
Been thanked: 160 times
Post by plush »
soulsonic wrote: 09 Nov 2020, 21:06 Do you mean something like this?:
http://smallbear-electronics.mybigcomme ... tary-1p6t/
Something like dis, I believe Image
Called subminiature pcb toggle switch
It still can be around .3mm taller than your regular alpha 9mm pot, so you may want to incorporate a thin washer on your pot shaft. Or may not.
Can be purchased from your local vendors, such as mouser, futurlec, jameco, etc., or via aliexpress/ebay or even directly from the manufacturer.
Acese1992
Post by Acese1992 »
once I've tried mouser.com, I didn't find what I was looking for
bmxguitarsbmx
Has thanked: 657 times
Been thanked: 203 times
Post by bmxguitarsbmx »
Acese1992 wrote: 17 Dec 2020, 17:03 once I've tried mouser.com, I didn't find what I was looking for
Yeah. Barely any parts to choose from.
