I'm in the process of modding a vintage Thomas Organ Crybaby. I was going to use some 1/4W carbon comp resistors that I already have to replace some of the stock 1/2W for mods.
Is this ok or should I be using matching 1/2W?
Thank you
I just took a second look at the Ohm's Law and... I don't get it ¯\_(ツ)_/¯. As I see it, resistor parameters that are usually relevant are its electrical resistance, maximum power dissipation and noise. I presume the OP will replace with resistors of the same electrical resistance, but half the maximum power dissipation. What am I missing?
You choose your resistor power rating based on it's maximum power dissipation in its current application, which can be calculated using ohm's law.The G wrote: ↑25 Oct 2020, 12:28 I just took a second look at the Ohm's Law and... I don't get it ¯\_(ツ)_/¯
There are no dumb questions - the responses on forums on the other hand...
