TA7136 Upgrade Adapter
how to mount an adapter ta7136 to tl072?
- plush
I'm not sure what do you mean under "how to mount"
ta7136 has a specific pinout
pin1 - frequency compensation
pin2 - non inverting input
pin3 - inverting input
pin4 - vcc-
pin5 - voltage compensation
pin6 - output
pin7 - vdd+
You need to match tl072's pins and leave frequency comp and voltage comp unused (unconnected)
Second half of tl072 should be tied to ground/vref rail like so
- deltafred
- Opamp Operator
Why not use the single opamp TL071?
- Yazoo55
Here is a link to a site explaining how to build an adapter using a TL071. I successfully used this when I built a Boss CE-1 clone.
https://ua726.co.uk/2016/09/08/ta7136-substitution/
