There are too many notes of people getting flummoxed on how to "Bias the FET" in the X100. Many have claimed that the FET is a booby trap. Few DIYers just got "some compression" rather than "correct compression" while many did not get any compression at all,
Here is a graph on effect of setting the compressor of an X100 in CLN mode. This is from the SPICE analysis of the X100, correlated to readings from a real X100.
Compression ratio too low:
In the graph labelled 4.44/6.46, the 100 X compressor has too low a compression ratio, hence the output is high.
With power supply of 6V, 0, -6V. the Opamp cannot output more than about 4.5 or 5V. The Opamp will clip for high input signals since more output is demanded but is not possible. This is shown at point where graph plateaus out for high signals. Clipping is not acceptable for a clean sound.
Compression ratio too high:
In the graph labelled 6.44/6.46, the compressor has too high a compression ratio. The compression is severe. The output is low. Some might like the sound of high ratio compression, almost like a limiter. However when the same compressor is shifted to EDGE and DIST modes, there will not be enough signal to drive these modes into severe clipping.
The Goldilocks setting range:
Somewhere in the middle is a whole range of acceptable compression ratios that neither distort nor give low output (estimated region in pastel green)
However only one of them is TOM's FACTORY SETTING.
That is why so many measurements were needed on a real X100 to determine what was the magic TOM'S FACTORY SETTING.
Unfortunately, we only measured one X100 so far. So we have only one reliable reading of TOM's FACTORY SETTING. However, I feel plus minus large range from that one reading is all within the acceptable green zone.
Meaning that suppose Tom wanted a compressor ratio of 4:1
Then maybe from 2.5:1 till 8:1 is all kinda good enough and satisfies the criteria of no clipping but high enough output
But low ratio like 1.2: 1 will clip and high ratio like 15:1 will give low output
It would be nice to get readings from other X100.
