Phase Vibrato Phaser Electronics Australia March 1969.pdf- (5.1 MiB) Downloaded 189 times
N. Williams & J Leo, Organ Tremulant Vibrato Phaser, Electronics Australia, March 1969 🇦🇺
- modman
- a d m i n
- Has thanked: 4287 times
- Been thanked: 2008 times
Full hi-res article in PDF:
- BMS1971
I did try it but not really working... Needed to boost signal at input and oscillation is really not stable...
"Eddit", wen I added the 4 missing resistors, work like a charm, not the most powerful phaser vibrato but very pleasant. I had great results with NSL32 optocouplers. but I will try LED/LDR tomorrow again, I tried some today but background noise was BIG...
- BMS1971
Update on built:
1 the best is to use only one lamp for all 3 LDRs à la Univibe.
2 USE trimpot in series with resistor (82R) on darlington who drives lamp effect is very sensitive to lamp brightness
3 40408 can be replaced by BC141
4 I used BC108B from CDIL
