Complete Maestro Service Manual, indexed PDF
Free online ressources on guitars, amps, effects, guitar technique and more. Dedicated to the fond memory of its founder SPeter Davidoff.
A very nice guy called Joe Palermo was going through some stuff and found this. He decided to donate the high quality pictures he took to a facebook group. I downloaded the pics and compiled it into an indexed PDF.
Here is a handy, perfectly readable lores version of this file. I need so sort some serverstuff out, then I will be able to host the higher quality versions I have. Done.
Maestro Service notes lores.pdf
Small size file.
(5.61 MiB) Downloaded 787 times
Maestro Service Notes_medium.pdf
Medium size file.
(36.96 MiB) Downloaded 405 times
Maestro Service Notes_large.pdf
Large size file.
(189.4 MiB) Downloaded 565 times
fantastic - thanks so much ;-)
Has thanked: 218 times
Been thanked: 857 times
Far out!! :shred: :shred: :shred:
Weird mistake in the FZ-1S schematic. Line drawn wrong shows output of fuzz connecting to R5 instead of R7, and R7 is connected to 9v. It seems the connections of R5 and R7 are swapped from what they should be. Is this already a known issue with the factory schematic?
borislavgajic
Has thanked: 131 times
Been thanked: 277 times
Post by borislavgajic »
:worship:
Nice crowd here.....
Thanks for posting Johan!
CodeMonk
Has thanked: 13 times
Been thanked: 54 times
Post by CodeMonk »
Awesome. I'm way into reading technical stuff, screw Stephen King :)
That Envelope Modifier might become the next version.of my current project.
aka180
Been thanked: 18 times
Post by aka180 »
:worship:
Wow they really want to keep that sustainer circuit a secret, didn't they! At least I know the values which is what I needed!
Jim-Analog
Has thanked: 32 times
Post by Jim-Analog »
Greetings,
Fantastic, thanks so much! Didn't know they made so much FX stuff, plenty of projects in there.........
Regards, Jim
george giblet
Has thanked: 180 times
Been thanked: 272 times
Post by george giblet »
The evince PDF viewer I have actually shows an Archive Type not supported error.
george giblet wrote: 22 Oct 2021, 21:09 The evince PDF viewer I have actually shows an Archive Type not supported error.
Thanks for the heads up -
You are using Linux?
Does this mean you are unable to access the file at all?
If you open the application first, then access the pdf, do you still get the error? https://gitlab.gnome.org/GNOME/evince/-/issues/1506
Do you have the same problems with other pdfs?
J
george giblet
Yes I'm using Linux, I tried opening the first two files with no success.
Your trick of opening the file directly worked.
The way I've got the browser set-up is it never view files *in* the browser, it always has the pop-up to open or save. If I choose opens it open the pdf in the Evince viewer as an external program with its own window.
Here's the results of the different opening methods:
- Opening via the link - doesn't work.
- Double clicking the file in the Firefox downloaded files list - works. (I thought I did that yesterday)
- Saving the file then open the file directly in the "Files" file manager - works.
Funny thing is I haven't seen that problem before. I must have about 5000 PDFs on my machine.
It's likely not all were viewed via the browser.
george giblet
You wouldn't believe it, I had another instance of this on a datasheet today.
Dr.Detroit
Has thanked: 19 times
Been thanked: 8 times
Post by Dr.Detroit »
george giblet wrote: 26 Oct 2021, 22:03 You wouldn't believe it, I had another instance of this on a datasheet today.
Yeah, I'm on a Gnome based Linux, and the built-in pdf viewer can get wonky. I use Firefox to view them when this happens. Seems like a kludge, but it works fine.
george giblet
I did a few updates on my system (Firefox 88.0 and Evince 3.18.2) and now it works.
I've been putting off updates for some time. The updater was failing because of Libreoffice and Wine. I had to manually set-up some new repository locations and import new ppa keys. The Ubuntu updater often screws up when the OS version falls down the list - total PITA.
uncleboko
Has thanked: 57 times
Been thanked: 38 times
Post by uncleboko »
It's fine in Windows 11.
