So, last year i aquired this beautiful thing:
It's a Meteoro(a brazilian manufacturer) Vulcano G100 100w 2x10, and if you look closely to its panel, it clearly shows its roots: it is basically a Valvestate 8080 copy (a weird copy, with a Valvestate preamp going into a Gallien Krueger 400RB power amp
And i've been doing all sorts of things to it like modding the clean channel to be more fenderish(wich took away a lot of the channel's headroom, and i'm still trying to figure out how to fix that) and adding a simple high pass filter to the power amp to kill the awful sub-bass, and also adding a cathode bypass cap to the tube's first stage, and so on.. And it already sounds pretty good the way it is, but i think it could be better.
So now, i wanna try this:
original schematic: https://www.thetubestore.com/lib/thetub ... ematic.pdf
The way this tube(currently a russian 6n2p, originally came with a 6bq7) stands in the curcuit right now it isn't doing much(just a clean stage followed by a buffer), so the idea here is to extract as much gain as possible from this single tube by turning it into 2 gain stages with its own gain control, followed by an opamp buffer(to substitute the cathode follower's function). And this should work, however, i have no idea of how big of a signal is gonna come out of that 2nd tube stage(and all i have to work with are a soldering iron and a cheap multimeter, so i can't really measure that preciselly), and if that is going to clip that opamp. And if does so, i wanna know about a more balsy buffer circuit with lots of headroom that would be able to withstand that without distorting the signal.
So, what do you guys think? Can this work? Suggestions?
