phatt wrote: ↑05 Apr 2021, 12:00As I have built many reverb circuits I would suggest researching before just building and hoping for the best.tome.talevski wrote: ↑04 Apr 2021, 09:51Thanks for those Kinski! I came across the moody option also.. hoping someone out there has the time and inclination to create a layout incorporating The G’s wet dry mods!![]()
Spring Reverb circuits are quite tricky and although a lot will deliver reverb,, many are less than impressive. (I should know cause I've built many and a lot are crap)![]()
Number one thing to Know with Spring Reverbs,,, The tank has to match the circuit you wish to build.
If that is not close then you are building something that will frustrate you and likely end up in land fill.![]()
Not at first obvious but Rod Elliot sells PCB's which can be modified for Reverb circuits,, It might help you![]()
https://www.sound-au.com/project34.htm
There is a ton of really useful info on Spring Rev here and hard to find this info elsewhere.
My circuit idea of using a small Tx for hiZ drive tanks is found on this page.
Rod kindly refined it.
https://www.sound-au.com/articles/reverb.htm
Front page of ESP is here;
https://www.sound-au.com/index.html
This would have to be one of the best web pages for DIY audio noobs who don't have the education,,and Very well written.
Phil.
Thanks for all that detailed info.. my research has also uncovered that warning.. not all tanks match all circuits.. like I mentioned in a previous post, im on the cusp of beginning the ruthenium circuit with a stomp box friendly tank.. see below..
http://guitar-fx-layouts.42897.x6.nabbl ... 38024.html
