Wobble Box Chorus/Vibrato
- Ripthorn
I created this project while messing around with the ES56033 chip that I used in my Stalker Double Tracker project. I figured out a way to get some modulation, but the chip seems to have an internal compensation circuit, which means you can't control delay time the same way you can on PT2399. However, it still results in a fun little project with some weirdness to it. You can get a walk through of the whole circuit along with all the build documents at my little webpage for it: https://scientificguitarist.wixsite.com/home/wobble-box. This project is free for personal, non-commercial use. Enjoy!
Exact Science is Not an Exact Science - Nikola Tesla in The Prestige
- pinkjimiphoton
- my favorite amplifier: my own, a redesigned princeton
- Completed builds: so fucking many goddamn pedals it would make your ass hurt just looking at 'em all!!!!!
there's videos that totally suck of about 90 of 'em here:
http://youtube.com/666pinkster
gimme a like: http://facebook.com/pinkjimiphotonrocks - Location: new world order land (formerly la-la land)
- Has thanked: 358 times
- Been thanked: 476 times
- Contact:
thanks for the project and the pcb bro! looking forward to building it!
Slava Ukraini!
Slava Ukraini!
- Reachahighernoon
Hey man I was wondering, is there a way to make the LFO more even in terms of wave shape? To make the chorus modulation smoother instead of having a major dip like a vinyl emulation pedal
- pinkjimiphoton
- Contact:
i dunno if that would be possible, like he said, this was an "accidental" vibrato. i think its the attack that ends up making the modulation happen on the one i built. it's cool for what it is, but i dunno how much more you could get out of it.
Slava Ukraini!
Slava Ukraini!
- Reachahighernoon
The question is does the ES56028 chip offer a better chorus sound than the typical PT2399 chorus and how easy it is to mix and match LFOs to suit my needs?pinkjimiphoton wrote: ↑03 Mar 2022, 16:26 i dunno if that would be possible, like he said, this was an "accidental" vibrato. i think its the attack that ends up making the modulation happen on the one i built. it's cool for what it is, but i dunno how much more you could get out of it.
- pinkjimiphoton
- Contact:
the straight answer is no. pt2399's suck for chorus too tho....
Slava Ukraini!
Slava Ukraini!
- Reachahighernoon
Honestly I thought the Sea Machine by EQD sounds awesome and since I didnt have luck creating something with BBD I thought about using chips like the ones stated abovepinkjimiphoton wrote: ↑03 Mar 2022, 18:05 the straight answer is no. pt2399's suck for chorus too tho....
Reachahighernoon wrote: ↑03 Mar 2022, 08:56 Hey man I was wondering, is there a way to make the LFO more even in terms of wave shape? To make the chorus modulation smoother instead of having a major dip like a vinyl emulation pedal
i'm not sure if you've seen this but it might be closer to what you're after.
viewtopic.php?t=31794
- Reachahighernoon
How hard would it be to turn this into a duo chorus like the Dimension P?asbestosaurus wrote: ↑04 Mar 2022, 11:43Reachahighernoon wrote: ↑03 Mar 2022, 08:56 Hey man I was wondering, is there a way to make the LFO more even in terms of wave shape? To make the chorus modulation smoother instead of having a major dip like a vinyl emulation pedal
- ppluis0
Hi folks,
Perhaps another kind of oscillator can be used to implement an stereo chorus: Quadrature Oscillator:
The values to have low freq has to be much higher than this diagram (68K and 2.2uF aprox)
R2 and R3 must be modified by a dual ganged potentiometer to vary the running freq..
R1 must be slightly lower in value to assure enough gain to maintain the oscillation.
As a side note, this circuit start to oscillate slowly resembling as if were implemented with vacuum tubes
Wit a couple of op amps we can obtain two (almost) perfect sinewaves always shifted 90º
- Reachahighernoon
This is oddly similar to the Dimension P LFO and inverterppluis0 wrote: ↑04 Mar 2022, 15:15 Hi folks,
R2 and R3 must be modified by a dual gan potentiometer to vary the running freq..
As a side note, this circuit start to oscillate slowly resembling as if were implemented with vacuum tubes![]()
- ppluis0
Has some similarities as they have two outputs, but instead to be exactly in opposite phase this design have a constant lag of 90 degrees.Reachahighernoon wrote: ↑04 Mar 2022, 16:04 This is oddly similar to the Dimension P LFO and inverter
Perhaps can be an improvement or can be annoying to play with a chorus constantly running from one amplifier to another.
Experimentation is needed...
