Orange Rockerverb Preamp J201 Problems
KeenVox
Post by KeenVox »
Hello everyone,
happy to make my first post, sad because it starts with a problem.
I built an Orange Rockerverb Preamp based on the attached schematic from pcb mania. It's a relativly straight forward build using the Rockerverb preamp circuit and replacing the tubes with j201 jfets. I dialed the jfets to 4.5V and everything sounds fine.
However as soon as I play hard on the guitar the sound slowly starts distorting and finally cuts out completely.
I measured the voltage on Q1 and I can see that the voltages slowly rises to 9V while I play. After that the voltage stays consistent and can't be reduced with the pot anymore, till I short the jfet, decharging it.
After that everything works fine till I play, then it starts charging up again, distorting and cutting out.
I switched the pot and even the jfet but the problem remains. I'm using SMD J201.
Any clues what's causing this behavior?
lcv
Been thanked: 5 times
Post by lcv »
q1 gate has no dc path to ground it seems
Manfred
Has thanked: 1597 times
Been thanked: 1300 times
Post by Manfred »
lcv wrote: 12 Mar 2021, 21:45 q1 gate has no dc path to ground it seems
I agree that there should be a resistor of 1 megohm between the gate of Q1 and ground.
KeenVox
Post by KeenVox »
That would be right after R1 correct?
The G
Grease Monkey
Has thanked: 407 times
Been thanked: 282 times
Post by The G »
Can go both before and after, just be sure it provides a DC path to the ground for the gate.. The tubes schematic has it after, but there are reasons for that (http://www.runoffgroove.com/fetzervalve.html).
KeenVox
Post by KeenVox »
I added the resistor to ground and now it works line a charm. The voltage sweetspot for good sound is a bit different now but it was easy to dial it in by ear.
Thank you very much for your help!
sdiazmun
Post by sdiazmun »
HI KeenVox!
Have you noticed that the capacitor values are different in each section of the PDF? What values did you use?
How similar does it sound to the original amp?
KeenVox
Post by KeenVox »
I used a prototype pcb from pcb mania before it was public with an own BOM. If I remember correctly the values were the same like the ones in the schematic. I think the sound comes relativly near to the real preamp. Either way it works really good as a dirty overdrive :). I think this one is a 1 to 1 copy of the original preamp circuit switching only the tubes for jfets.
wormwood
Post by wormwood »
What are the "0/1" and "1/1" pads between R5 and C5? I noticed that there is the same junction on the tube Rockerverb 50 mkII schematic that is attached to a SPDT relay. Is this where the clean/dirty channel switch would go?
