Looks great. Can you add my CC license somewhere? Some attribution next to your own name would also make me happyjimilee wrote: ↑22 Sep 2022, 02:50 Sent a PCB to be fabbed. I got no image hosting set up, here's a drop box link.
https://www.dropbox.com/s/h3uox0mlbz7du ... n.png?dl=0
I can post the Gerber zip after it's verified. I'll have a few leftover as well.
Clown Centurion (reworked Klon) [documentation]
- dylan159
I can do that, I made sure to put it on the schematic. The main reason my name is on the board is so, if the extra ones get out, they'll know where to find build docs. The credit is definitely all yours. I get it on the next batch of boards. I sent the protos to the fab house last night.
- dylan159
Good good, attribution is one thing, even better if it leads to all the resources we have about this and maybe our other projects. Be sure to post updates!jimilee wrote: ↑22 Sep 2022, 21:08 I can do that, I made sure to put it on the schematic. The main reason my name is on the board is so, if the extra ones get out, they'll know where to find build docs. The credit is definitely all yours. I get it on the next batch of boards. I sent the protos to the fab house last night.
- jeepe
- Completed builds: I might be at level 2, so to speak..
not totally green, but that's all :)
my "level" is about building a big muff... medium complexity :)
I'll never build a DS-2, for example :)
even though I'm a layman to electronics
I'll never build anything without seeing the actual schematics too...
my all time favorite: Fuzz FAce
it is an always ongoing project..
I want to end up strumming some strings at the end of the day, whatever the sound
I'm so sad that this beautiful culture (and freedom movement) is totally ephemeral - Location: Budaspest, Europe
- Has thanked: 568 times
- Been thanked: 21 times
here: https://www.diystompboxes.com/smfforum/ ... msg1104023
it was PRR, not RG
pedal building, tracing and sharing is such a beautiful freedom movement... If only it could be viewed as a future heritage, but it really is ephemeral, as it seems
It's verified. Eagle files and zip file if you wnt to upload to JLCPCB or similar.
https://www.dropbox.com/sh/0pgaxs6vqgyf ... mplia?dl=0
- dylan159
I've taken a look. Good job. Is the tone control labeled TOAN? ha, I like it. Also this is a creepy clown, you got that right.jimilee wrote: ↑22 Oct 2022, 19:15 It's verified. Eagle files and zip file if you wnt to upload to JLCPCB or similar.
Yep, all of my layouts with a tone control are labeled Toan. That's what we're all chasing.dylan159 wrote: ↑23 Oct 2022, 10:53I've taken a look. Good job. Is the tone control labeled TOAN? ha, I like it. Also this is a creepy clown, you got that right.jimilee wrote: ↑22 Oct 2022, 19:15 It's verified. Eagle files and zip file if you wnt to upload to JLCPCB or similar.
I am working to get more distortion out of it early on. About 2/3 of the rotation doesn't do much at least with my D9k diodes. The value could possibly be taken down from 100kB to about 25kb.
- dylan159
That will also make the signal going into the gain stage quieter! try to decrease r6 and increase c5 proportionally instead.jimilee wrote: ↑23 Oct 2022, 16:48 Yep, all of my layouts with a tone control are labeled Toan. That's what we're all chasing.I knew that clown was right the minute I saw it.
- dylan159
I was informed. Makes me feel a bit giddy
Hello. Thanks for putting this layout together, jeepe.jeepe wrote: ↑18 Sep 2022, 06:52 hi,
as to the vero layout, I had to re-check it before uploading, it is unverified, but I believe it's correct (I do make mistakes, but not often, and I've re-checked it)
I've changed your chosen PSU design, minor changeas you see, I used a diode in series not to the GND for reverse polarity protection
(I've read opinions, extensively, about the "connect to GND" solution, and accepted that it will not necessarily protect any parts of the circuit, and leave mess when a reverse polarity PSU connection happens)
all files are attached, anyone feel free to adapt it, correct it, etc...
the PDF has the links and holes map, too... the PNG only has the populated board only
(but anyone can export it for themselves)
PS: for anyone editing the DIYLC file, the parts' names are NOT correct, that is, "R2" might be "R2", according to the schematic, but other parts will not match their names in the schematic, so, keep to the VALUES, and don't believe the "NAMES"![]()
I made a true bypass version based on your layout that's like 98% the same, just without buffered bypass. A few minor differences:
- I have the 1M pulldown on the input going to Vr like like in the schematic, whereas I think yours goes to ground
- I think you're missing a jumper to ground on one of your 100uF power filter caps
- A couple electronically irrelevant changes to accommodate parts placement that works for me (like allowing more physical room for the reverse power protection diode)
- Mine was slightly noisier than my other clone. dylan159 suggested that C10 should be larger than C9 (not a ton, just the bigger one within the tolerance). I didn't measure them before soldering, so I tacked another 100pF in series with C10, and it became quieter than my other one. I've shown that it my drawing, but I don't think it's strictly necessary
More info on my build is here: https://dunningkrugerfx.com/forever-boner
- dylan159
Great work to both chip and szukalski. Glad the capacitor did the trick.
