Caline came out with e Big Muff clone too, the "B-Fuzz", but I haven't bothered to open that up because I can tell you right now it sounds identical to my Nano Muff. What miniscule difference exists could owe to component tolerances.
The effectslayouts.blogspot.com page links freestompboxes.org for the schematicAntigua wrote: ↑31 Mar 2021, 17:24 OK, I figured this one out, it's a "Vertex Steel String", an earlier version of the pedal that didn't have a toggle switch. The components match this diagram exactly http://effectslayouts.blogspot.com/2018 ... tring.html
Well, the Vertex version of the Booster 2.5 circuit does use R.G. Keen's noiseless biasing scheme for mu amps, as described here:Antigua wrote: ↑01 Apr 2021, 05:12I see it said on another forum that the Six String Singer is a copy of the Booster 2.5 Maybe, but in any case, the two schematics above are only about 85% the same, and Caline pedal is much closer to the Six String Singer schematic. . In fact, they're so different that I'd be surprised if they sounded wholly alike. The topography is very similar, but the component values around the tone control are all fairly different, and elsewhere.
Are you two separate people? Or the late queen of england?stolen wrote: ↑08 Jan 2023, 18:04 Hey,
got one of these the other day mostly because the artwork is adorable and we needed smth low gain ish anyways. The stock circuit was a little bit tame for us and lacked bite, so we bypassed the first stage mu amp source with a 47nF cap and it worked wonders. You can perform this mod without disassembling the pedal, just solder in the capacitor as shown. We tried boosting the second stage too but we didn't like it much, but if you do want to try we'd recommend a higher value cap there, maybe an electrolyte. We marked the 2nd stage mu amp source and nearby jack ground in the pic too.
Maybe this helps someone some day!
