Strange problem with Boss SD-1 [SOLVED]
I have a vintage Boss SD-1 that works when engaged but no sound when bypassed.
I’ve searched online to see if anybody else has experienced this same issue. Only common thing that I found was the opposite problem- works in bypass mode but no sound when engaged.
Anybody have any ideas?
- Manfred
- Has thanked: 1675 times
- Been thanked: 1360 times
First bridge drain to source of Q1 and see if the signal comes out.
- CheapPedalCollector
Bad Q2 maybe
- Manfred
Ok, then measure the voltage at the gate of Q1 in both switching states.I’ve bridged the drain and source of Q1 and the signal came back.
Is there a noticeable voltage difference between the states?
I measured the voltage of Q1 in both switching states- no change, 0V both states.
- Manfred
Measure the voltages on the collectors of Q3 und Q4 in both switching states.
Does the illumination of the LED change between on and off when switching?
Q3 collector reads 6.29V bypassed and 0V engaged.
Q4 collector reads 0V bypassed and 6.3V engaged.
LED illumination doesn’t change between on and off when switching.
- Manfred
The switching control circuits works.
Measure the voltage on the cathode of the diode D7 for both switching states
and check if pin1 of the Level pot ist still connected to ground.
Voltage on the cathode of D7 reads 0V bypassed and 5.75V engaged.
Pin 1 of the Level pot is connected to ground.
- Manfred
- Manfred
Sorry, Phatt is right, my mistake.Voltage on the cathode of D7 reads 0V bypassed and 5.75V engaged.
At pin 1 of the potentiometer must be about 4.5 volts to measure.
if you can measure this 4.5 V there, then D7 or Q1 can be defective.
You can check the diode by ohmmeter.
Without operating voltage you can also check the JFET with the ohmmeter, there should be a resistance in the ten ohm range between drain and source.
I measured 4.6V at pin 1 of the potentiometer. Diode didn’t have any resistance at the drain and source.Manfred wrote: ↑09 May 2021, 15:36Sorry, Phatt is right, my mistake.Voltage on the cathode of D7 reads 0V bypassed and 5.75V engaged.
- Manfred
The diode does not have source at drain, ich meant the JFET Q1.I measured 4.6V at pin 1 of the potentiometer. Diode didn’t have any resistance at the drain and source.
- Manfred
As already mentioned, without power supply or battery the resistance between drain and source must be low.
If in your SD-1 the 2SK30A type for signal switching are used, this resistance is about 400 ohms.
I read this resistance value of the 2SK30A on one of my effect units with identical switching circuit.
This value is higher than expected, with the typical JFET for switching application this value is in the range of some tens of ohms.
If the measured value has a very high resistance or is not measurable then Q1 is probably defective.
I used an audio probe and traced the input signal path and noticed that the signal got quiet after R1 into C1.Manfred wrote: ↑09 May 2021, 22:17 As already mentioned, without power supply or battery the resistance between drain and source must be low.
I noticed that R2 had been replaced with a 2.2K resistor, looks like it’s the mod value for R6- botched mod by the previous owner!
I removed the 2.2K resistor and replaced it with the stock value 470K- the pedal works in bypass mode again.
