http://www.diyguitarpedals.com.au/shop/ ... ucts_id=35
I got this idea from seeing a tubescreamer moded with a bad bob boost circut see pic below.
How would i connect the 2 together if i wanted to have the boost after the overdrive?
Is it a matter of wiring the boost to the output lug of the overdrive etc?
I guess it would be similar to making a dual overdrive/boost pedal but in an existing housing?
Id like them to also act independently e.g i can use the boost with the overdrive off and vise versa
Thanks Mark
