I got an enclosure from Franco @ Argenziano Effetti, and originally was going to etch my own board but decided it was easier to get one pre-done from Brook at Pigeon FX. I used NOS 1/2w resistors (not sure brand, probably AB, had a ton of them), new Nichicon caps, some greenies from Tayda, BC108 in Q1 and 2SC945s for most of the remainder, but ran out and had to temporarily use some 828 pulls.
Originally I had some issues from wiring the transformer for 220v and I'm in the USA, so I corrected that. Then I had the PCB shorting against my standoffs accidentally (found this when the case halves were sparking
I'm more than likely going to swap out all of the transistors in the circuit with 2SC828s when they arrive but I'm wondering for the more experienced Vibe builders here (religiously went through the Sinner build thread and used most of the resources) if anyone has suggestions on where to look if I'm barely passing signal and no effect. I also noticed the transistor next to the trimpot can barely get a reading if the intensity is more than halfway dialed in. Flashing OL..
