Dunwich - Wizard Fuzz [traced]
- my favorite amplifier: Ampeg
- Completed builds: Veroboards builds:
Throbak Overdrive Boost
Wampler Ecstasy
Creepy Fingers Doomidrive
Black Arts Quantum Mystic
Roger Mayer Voodoo Bass
Idiot box Blowerbox
Hudson Sidecar
Pcb builds:
Fulltone 69 (GGG kit)
Russian Big Muff (Musikding kit)
EHX Bassballs (home etched using Topopiccione layout)
BJFE BBOD (home etched, thx FSB)
Triangle Muff (Guitar PCB board)
Deluxe Bass Fuzz (home etched,gausmarkov.net layout)
Clone Theory Chorus (Celeste pcb from lectric-fx)
Cornish G2 (home etch, layout thx FSB)
Shin-Ei FY-2 Ge version (home etched, own layout)
Klon (Aion Refractor pcb)
Mutron Phasor II (home etched, layout thx JohnK)
Sunny-T (pcb by guitar pcb)
Rocket Overdrive (pcb by Pepers' pedals)
Sonomatic Deluxe Tape Delay (pcb by Skidmark)
Black Arts Quantum Mystic (adapted storyboardist layout) - Location: Lausanne, Switzerland
- Has thanked: 36 times
- Been thanked: 110 times
Hi all,
Here are some pictures of my personal Dunwich Wizard Fuzz #85. As it's quite a rare and now unobtainium unit, I decided to trace it.
I carefully took it apart, unsoldered all components, measured the resistors with a multimeter, measured the transistors with Atlas DC55 and noted everything down.
Then I traced it using Illustrator and drew a schematic on Kicad. I made sure my schematic doesn't contain any error, as I redid the original pcb layout on Kicad.
P.S.: there was a small mistake in my tracing. Gain lug 1 should go to ground. I made the correction and updated the files
There you go:
There you go:
Wampler Ecstasy
Idiot box Blowerbox
Hudson Sidecar
Pcb builds:
I will gladly share the kicad files if someone is interested. I still need to create a project specific library for the symbols and footprints I used, so that it can be shared.
Wampler Ecstasy
Idiot box Blowerbox
Hudson Sidecar
Pcb builds:
Here are my Kicad (version 5.1.9-0-10_14) files. I created a zip file in which are all documents you need in Kicad.
Just extract the zip file and put the extracted folder directly in your Kicad projects folder.
files corrected. Gain 1 now goes to ground, as it should
Wampler Ecstasy
Idiot box Blowerbox
Hudson Sidecar
Pcb builds:
I had a mistake in my schematic/tracing: lug 1 of gain pot should go to ground.
I corrected both the images in my first post and the docs in the zip file.
- EmmG
Vince, thanks for such a great tracing job! This is is a really heavy doom fuzz.
I built it using this vero layout:
dirtboxlayouts.blogspot.com/2021/05/dunwich-amplification-wizard-fuzz-big.html
https://dirtboxlayouts.blogspot.com/202 ... z-big.html
I suppose that the bottom layer of the pcb is to ground.... Do you maybe know what's connected to the top layer ? Thanks
