DIY marshall preamp quesstion
I'm building a sort of jcm800 type tube preamp with a master volume right after the cathode follower/tone stack stage. Nothing unusual. My question is do I need a coupling cap after the master volume? This will be the output. I know this is obvious to most of you, but I'm not sure. Any help is appreciated.
- plush
If there's a gain stage or phase inverter after master volume, then yes, you need a coupling cap after it.
Also, it should be useful to add a series resistor to protect the tube from shorts to ground.
- Screenshot 2021-07-03 145458.png (13.13 KiB) Viewed 1416 times
- phatt
If this is a stand alone preamp then YES you need a cap to decouple the stage.
Be aware the output of your preamp is the tone stack Volume pot which relies on the High Z of the PI (assuming the classic Marshall circuit topography).
The classic Valve tone stacks are Hi Z output and if the next stage is not hi Z input then it loads down the effect and so your tone controls won't work as effectively. The result may be rather disappointing.
Adding a HiZ buffer stage will guarantee the tone stack will work into most anything.
Phil.
Phil.
