D. Gibbs & I.M. Shaw, Guitar Sustain Unit, Practical Electronics, October 1977 🇬🇧
Free online ressources on guitars, amps, effects, guitar technique and more. Dedicated to the fond memory of its founder SPeter Davidoff.
Full article in PDF:
Practical-Electronics-1977-10 Sustain.pdf
(658.5 KiB) Downloaded 185 times
mictester
Has thanked: 32 times
Been thanked: 825 times
Post by mictester »
That's a really good sustainer. The transistors in the audio path need to be low noise ones, but the ZTX384W is made of unobtainium these days. I have built a variation of this circuit using BC109C which doesn't hiss, and I used the 2N3904 / 3906 for the LED driver. It can easily be built on Veroboard, and like my Really Cheap Compressor, it needs to be in a light-tight box. Some players prefer this design because of its somewhat unusual sustain characteristic. It does the "duck and swell" thing really well if you have a high output guitar.
BMS1971
Has thanked: 42 times
Been thanked: 31 times
Post by BMS1971 »
mictester wrote: 07 Jul 2021, 22:08 That's a really good sustainer. The transistors in the audio path need to be low noise ones, but the ZTX384W is made of unobtainium these days. I have built a variation of this circuit using BC109C which doesn't hiss, and I used the 2N3904 / 3906 for the LED driver. It can easily be built on Veroboard, and like my Really Cheap Compressor, it needs to be in a light-tight box. Some players prefer this design because of its somewhat unusual sustain characteristic. It does the "duck and swell" thing really well if you have a high output guitar.
What did you used to replace TR4? 2N3906 as well? I was considering BC214B...
mictester
Post by mictester »
TR4 needs to be low noise too, so the one I tried used a BC179C. If you look carefully at the circuit, it's not too far removed from the old "Roland" Sustain from the 1970s, or even the Colorsound "Supasustain", but it only needs 9V.
