Practical-Electronics-1967-11 Fuzz box 04.pdf- (410.76 KiB) Downloaded 137 times
A.J. Bassett, Fuzz Box, in: Practical Electronics, Nov 1967 🇬🇧
- modman
- a d m i n
- Has thanked: 4287 times
- Been thanked: 2008 times
Article in hi-res PDF:
- cspar
The type of transistors it calls for are Micro Alloy Transistors which aren't common bjt's.
You might find some in your junk box if you've salvaged some old radios.
"Just because the forgoing circuits have produced results there is no reason experimenting won't lead to added results." L. E. Darling, in his article containing the earliest published vacuum tube synthesizer circuit, Popular Science Jan 1920
