El Musico Loco - Wee Beaver Fuzz [traced]
Hi!
I had the occasion of making photos of both versions of the Wee Beaver Fuzz.
So here are the photos and a schematic.
Of what I can tell, the only difference between the big and small version is an additional capacitor in the small version.
It's a brilliant fuzz based on a silicon Fuzz Face and a Big Muff tone stack as you can probably see.
The circuit was apparently an inspiration for the Chase Bliss - Ayahuasca. One cool mod would be to make the gain variable.
Don't hesitate to tell me if you find an error.
Edit: Changed C4 placement
- weebeaver6.jpg (89.05 KiB) Viewed 1769 times
- weebeaver3.jpg (64.77 KiB) Viewed 1769 times
- weebeaver1.jpg (100.73 KiB) Viewed 1769 times
Science is art. Art is science.
https://electric-canary.com
- Manfred
- Has thanked: 1597 times
- Been thanked: 1300 times
what are the dimensions of the board?
Sorry, I don't have them with me anymore so I can't mesure.
However, in the small version, the board occupies the whole 1590A surface.
In the big version, the board is very small as you can see. You can probably guess with the pots dimensions.
- Manfred
Thanks, I will find out.Sorry, I don't have them with me anymore so I can't mesure.
Yeah you're right, C4 was in the wrong place, I updated the schematic. Thanks for the heads up!
- Dr Tony Balls
I saw the Fuzz Face mentionned multiple times about that pedal, that's why I said that.Dr Tony Balls wrote: ↑14 Jul 2021, 14:02I dont see any part of this that's based on a Fuzz Face, imo. Im sure its a cool circuit, just an odd reference.
But yeah, it's an adaptation of another circuit loosely based on the FF. So just transistor stages tbh.
- Nocentelli
- Has thanked: 1115 times
- Been thanked: 939 times
never seen that bias arrangement before: the first 2 transistors alone do a nicely nasty fuzz with very few parts - like an even more obscene fuzzrite
