Variable Line Out Box help ?
Soulchief
Post by Soulchief »
Variable Line Out Box ?
I ran a search and I know this has been talked about in various ways but a lot of the links are dead..
Could anyone layout how to make a ‘Variable Line Out Box with a Ground Lift switch’ for various tube amps up to 100watts to route to a WET Rig? I don’t need any cab simulation..
Thru Speaker Jacks
Potentiometer
Line Out Jack
Ground Lift Switch?
I do understand they are NOT Load boxes and must have speakers connected.
I just don’t know about values..
I see some people mention output impedance of the Line Out making them really low (under 1K) and some say 10K.. ?
I’m just looking for variable level control, transparent line out, and a possible ground lift incase needed.
Thanks for any help
phatt
Been thanked: 338 times
Post by phatt »
Dead simple to make up. :thumbsup
Wattage and Z match are not important, you just need a divider.
I've built several of these and works well.
It works out about 20/1 division. If 25 k pot is not enough just use 50k.
Phil.
