Demon FX King Spark Overdrive [schematic]
I got one of these cause they seemed cool. It sounded alright when I played it so I ended up tracing it to see what was going on under the hood. Going off the other pedals by this brand I'm pretty sure its a clone, not sure exactly what it's a clone of but there are some familiar elements. A TS style soft clipper with switchable asymmetry into a two-band Baxandall followed by a JFET buffer. (Yes, I know there's a gate resistor 'missing' from the buffer, it is not a tracing mistake, and the circuit seems to work fine without it).
Also I'm fairly new and still don't know how to add the cool [Schematic] tag to the title, maybe a mod could help, thanks :^).
- CheapPedalCollector
I bought one of these, I have to say this is an interesting pedal and has a lot of amp like compression/sustain that I've not heard similar circuits achieve. It sounds really really good, I'm impressed and it's also very quiet. I'll take mine apart and try to verify this schematic.
- dmc777
Does this have similarities to the old DMB Pedals Sparkle drive? Some of it looks similar. I believe it’s the celestial drive on pedalpcbCheapPedalCollector wrote: ↑16 Feb 2022, 02:08 I bought one of these, I have to say this is an interesting pedal and has a lot of amp like compression/sustain that I've not heard similar circuits achieve. It sounds really really good, I'm impressed and it's also very quiet. I'll take mine apart and try to verify this schematic.
Hrm no that looks more like a Morning Glory.
I need to take mine apart and trace it, I've just been super busy with repairs lately.
- dmc777
Trace what? The DMB pedals sparkle drive? I need to grab one if those off pedalpcb i used to love that pedal.CheapPedalCollector wrote: ↑21 Nov 2022, 09:03Hrm no that looks more like a Morning Glory.
- dmc777
Oh my bad I thought you’d posted the schematic above. My mistake.
Just re-read your description. Probably another reason I thought their May be similarities to the sparkle drive. I think I’ll have to pull the trigger on this one.
I’ve had some good and bad ones on the budget pedals. Have had better luck with the normal size rather than then the minis with the mosky silver horse, deep blue and mooer elady being the exception.
I have a few extras that I haven’t seen uploaded that I’ll try to get too. However I’m no schematic tracer lol.
- ppluis0
Hey !!!
What is the purpose to use a voltage doubler ??
After all, the op amps can't hit the rails if the supply were only 9V as in all others TS clones as the diode clippers limit the available operating range on their outputs.
I personally think that is due a lack of understanding of this boutique builder
- FiveseveN
You could still distort the second op amp if you really wanted to (max eq and high input signal).
But it was DESIGN BY USA! Or designed and built by handmade, not sure yet.
- ppluis0
This is also can be happen in the Xotic RC or AC boosters
This diagram has a 15K missing resistor in series with R4 and also the negative leg of the volume pot must be connected to GND !!
It's definitely similar, but still different as the first gain stage is non-inverting and the treble control has 6.8nf caps, the other interesting thing is the 2n5457 on the output. That part is what I need to investigate as it seems to be missing a gate bias resistor. It may be hooked up as a gain stage too, I'm unsure. I'll go take mine apart now I guess as I have free time today.
- dmc777
The 2n5457 on the output followed by the level was what reminded me on the sparkle drive.CheapPedalCollector wrote: ↑26 Nov 2022, 00:55 It's definitely similar, but still different as the first gain stage is non-inverting and the treble control has 6.8nf caps, the other interesting thing is the 2n5457 on the output. That part is what I need to investigate as it seems to be missing a gate bias resistor. It may be hooked up as a gain stage too, I'm unsure. I'll go take mine apart now I guess as I have free time today.
It's definitely worth 32 bucks, I like it, it has nice compression without clipping too hard.
- dmc777
Once again I called this the “sparkle drive”. I mean the damn Stellar Drive from the old DMB pedals. Interesting drive. With the gain up and pushed it can get almost fuzzy. Can get a great “Time” rhythm and solo using this as rhythm and kicking on prince of tone into it for solo. Works well with the volume knob. Perhaps that’s why it needs to be pushed.dmc777 wrote: ↑26 Nov 2022, 04:20The 2n5457 on the output followed by the level was what reminded me on the sparkle drive.CheapPedalCollector wrote: ↑26 Nov 2022, 00:55 It's definitely similar, but still different as the first gain stage is non-inverting and the treble control has 6.8nf caps, the other interesting thing is the 2n5457 on the output. That part is what I need to investigate as it seems to be missing a gate bias resistor. It may be hooked up as a gain stage too, I'm unsure. I'll go take mine apart now I guess as I have free time today.
I’d love for someone with the actual knowledge to “upgrade” the stellar driver circuit but I’m small time lol.
- ppluis0
Hi dmc,
Perhaps an easy experiment to do with this circuit is solder an 8 pin IC socket in the pcb and try different sigle op amps to compare their results.
For example the LF351 and also TL071 datasheets indicates an slew rate of 13 V/usec which is more than enough to audio applications.
But lower speed single op amps as LM308 and OP77 appearing in the original and recreations of the RAT has only 0.3 V/usec and gives the characteristic response of these pedals.
If you place in that socket an OP07 (designed for industrial applications requiring low drift) that have a merely 0.17 V/usec of capacity, the output bring us a condition named "slew rate distortion"
- dmc777
That’s pretty good info my friend. Certainly nothing I’d thought of. I’ve only heard of slew rate when talking about rats. Thanks for the suggestionsppluis0 wrote: ↑20 Jan 2023, 11:22Hi dmc,
