DIY ISO Variable Line Out Box Layout? (Suhr, CAE)
Does anybody have a Layout or Schematic for a DIY ISO Variable Line Out Box like the Suhr or CAE?
— Jensen JT-11-FCFL 1:1 600ohm Transformer ?
— Variable Potentiometer
— Ground Lift Switch
— Phase Reverse Switch
— Speaker In / Thru
— Line Out 1/4”
— Enclosure
I believe these would be the parts but I don’t know ‘Pot Size’, if any resistors are needed, or how to hookup..
The Suhr and CAE ones are really expensive and can’t be found currently so I though I’d make one but there is very little info out there that I could find at least…
— Speaker In / Thru
— Line Out 1/4”
— Enclosure
- ppluis0
Hi Soulchief,
There is the diagram for a well reputed DI: Countryman model 85
Take as a basis of your requirements as it already has speaker thru capability and is inherently ground isolated.
The other features you need can be implemented (IMHO):
- Phase reversal => A 2PDT switch to reverse the secondary of the transformer between pin 2 and 3 of the bal out.
- Variable potentiometer => Replace the switch S1 with a suitable pot.
- GND lift => open pin 1 of XLR from ground by means of a SPST switch
1/4" line out can be taken from the primary side of the transformer but there is always ground referenced
- Manfred
- Has thanked: 1597 times
- Been thanked: 1300 times
Do you know the transformer data?
- ppluis0
Hi Manfred,
I have not even seen one of those boxes personally...
This is a diagram that I found a long time ago on the web and it seems that it is no longer available, so the exact characteristic of the transformer are unknown.
I think that a test can be done making a prototype with a bifilar winding as 1:1 turns ratio and a suitable air gap in the core.
600 ohms load can be driven (IMHO) with the couple of NPN transistors connected as in the diagram...
- Manfred
Hi Jose,
thanks for your suggestions.
Manfred
Manfred
