Joyo Vintage Phase problem?
Hi y'all, new to this forum.
I've aquired a JVP pedal for cheap, and it sounds great.....however.
When footswitch is pressed to turn ON this unit, there is a delay (3/4 sec?) between bypassed signal and wet signal. Very annoying and it disrupts your flow.
This is a true bypass pedal, so no switching components involved? It sounds electronic, not mechanical.
Should just buy an MXR........
- CheapPedalCollector
Sticky switch sounds like, it's a standard 3pdt, replace it.
There are 3 poles....the LED illuminates immediately when turned on, and there is no perceived delay switching from on to off.
Probably defective unit. Mine works perfectly, unless the voltage gets too low.
