To reach the gain of the actual output stage your first guess was actually very close!snk wrote: ↑20 Sep 2021, 19:30So, am I right assuming that with R1 = 47k and R2 = 6.8k, I would stay in the suggested values ballpark (so keeping thermal noise low), and reach +18dB gain?asbestosaurus wrote: ↑20 Sep 2021, 08:18 As an aside
Gain calculation, if you (or other possible readers) aren't aware, is (R1/R2)+1.
For an answer in dB, take the log in base 10 of the above result and multiply that by 20.
To make the stage a unity gain buffer, short R1 and remove R2 completely.
What is the gain of the original pedal (as there is no "R1 & R2")?
If you want to match the frequency response closely too then a few more components are needed.
