Barber Electronics - Edge Hog  [traced]
graybench
Has thanked: 18 times
Been thanked: 131 times
Post by graybench »
Hey all, Joe from GBE here.
Found this Barber Edge Hog on Reverb, seems like a pretty under-the-radar pedal.
Did a video on it for my YT channel. Sound samples, gutshots, similar schematics, etc.
Basically a Rat with germanium diodes and a second opamp stage for the bass control.
SCHEMATIC:
barber edge hog.pdf
(16.25 KiB) Downloaded 234 times
andy-h-h
Has thanked: 20 times
Been thanked: 39 times
Post by andy-h-h »
Nice - great video too.
graybench
Post by graybench »
In case anyone wants a visual representation of the edge hog's bass control:
jacklawson
Post by jacklawson »
Did you ever figure out what was in that little gray bundle attached to the "Edge" pot?
I breadboarded this off your schematic and get a high pitched whine in BYPASS when "Hog" is cranked up to pretty much max and "Edge" is adjusted. Does this happen on the original pedal?
Isn't that resistor attached between pins 2 and 3 on "Hog" a 200k, not a 20k?
This thing sounds awesome, I'd just love to get rid of that whine! Thanks for the great work on this!
graybench
Post by graybench »
jacklawson wrote: 17 Nov 2021, 17:25 Did you ever figure out what was in that little gray bundle attached to the "Edge" pot?
Those are the hard clipping diodes, any germanium diodes should work fine.
Hog parallel resistor is definitely 20K.
Whine could just be a by-product of breadboard. Gotta put it in an enclosure.
mirosol
my favorite amplifier: Been on Bogner for quite some time now.
Completed builds: Over 1000 and counting.
Has thanked: 190 times
Been thanked: 446 times
Post by mirosol »
Very nice work Joe! I've been watching the teardown videos more and more. These are great, thank you!
I drew up a vero layout for this circuit in case someone wants to try it out. Unverified at the time of posting this.
http://tagboardeffects.blogspot.com/
http://mirosol.kapsi.fi/
"No such thing as innocence" -Iron Chic
