DOD FX20B Stereo Phaser-Not so Stereo
acidblue
Post by acidblue »
Hi there, just acquired FX20B Stereo Phaser, but it doesn't sound very stereo to me, all the swooshing only comes from the left channel, the right channel seems to be just the dry signal.
Is this normal for this pedal or is there something wrong?
Shouldn't the swooshing effect be across both channels?
mauman
Has thanked: 435 times
Been thanked: 184 times
Post by mauman »
According to the schematic, you should get the same signal from both output jacks. viewtopic.php?f=1&t=16761&p=186126#p186126
acidblue
Post by acidblue »
Yes, I noticed that myself, but was curious to see if any one had the same experience with their FX20B.
Looks like I'm gonna have to pop it open and check the PCB/Connectors. I have some Deoxit and was planning out cleaning the pots anyway.
Which leads to my nest question, is there anything specific I should be looking for?
mauman
Post by mauman »
If you're getting wet + dry signals on one jack, and just dry on the other jack, the fault has to be right at the input of the op amp that's driving it. There are different op amps driving each jack, but both share the same wet and dry signal inputs. The jack is OK since you're getting dry signal on it.
