Rat differences?
darrencp
Been thanked: 5 times
Post by darrencp »
Hey all!
I know there's a million posts on Rat's but I thought I'd ask another :)
I'm looking at the below:
https://www.dropbox.com/s/6hfeotzmszcpl ... t.pdf?dl=0
And from the component list there's a few changes between each variant, not just the diode clipping:
https://ibb.co/YbYN49N
But I've seen a lot of posts saying just change the clipping diodes to toggle between variations - so wondering if the toggle of diodes is enough or should the extra components be changed too?
I'm looking at trying to build a multi-rat pcb and toggle via rotary - hence the question.
Thanks in advance,
Darren
plush
Has thanked: 36 times
Been thanked: 172 times
Post by plush »
darrencp wrote: 12 Oct 2021, 08:08 so wondering if the toggle of diodes is enough or should the extra components be changed too?
Hi Darren,
In all honesty, it depends on what you are trying to achieve.
2 things:
- circuit simulator https://www.falstad.com/circuit/
- breadboard
Jarno
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Alembic F2B (tube preamp)
Opamp and FET buffers
Tables
Bookshelves
Basses
So many things! :D
Has thanked: 27 times
Been thanked: 81 times
Post by Jarno »
I really dislike breadboarding (because I am colourblind, and dread messing up my component stock and buggering up a build), and I don't think simulating will give you the answers you seek.
I'd layout a little board, get 10 from china for little money. Has the advantage that you simply put the one you like best in a box.
Or build one with relays for the component variants like the jhs pedals (muff and tubescreamer)
darrencp
Post by darrencp »
Hi both.
We'll what I'm trying to achieve is asking if a toggle for only the diodes works or does it need a full component swap to have a multi-rat box?
I'll breadboard it and try it - was just asking in advance incase someone (which I'm assuming they have) has already done it and could save me one job.
@jarno - how weird... I'm colourblind too, so I feel your pain haha
Darren
Jarno
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Tables
Bookshelves
Basses
So many things! :D
Post by Jarno »
35% of the male population, so yeah :D
Different things will have different outcomes, but if you only do the diodes, then yeah a switch will do. Add a socket for the opamp so you can pull it and put in something else.
ggbb
Completed builds: Monte Allums Boss CS-3 Opto-Plus Mod
Run-Off-Groove Improved EA Tremolo (modified)
Modified Fuzz Face
Orange Smoothie Compressor
OCR (Modified RAT)
BSIAB2/Pinnacle Hybrid
Cardinal Tremolo
Bluesbreaker
Notorious OD (Modified Bluesbreaker)
Timmy
Boss CS-2 Compressor
Scarab Deluxe
Mini Copy Chorus (Modified Small Clone)
PAiA Gator
Hot Cake
ODR-1
Mostortion
OCD v2
Straight Up Clean Boost/Cut
Been thanked: 19 times
Post by ggbb »
That project is not entirely accurate. Most notable is R12 which is NEVER omitted in the Turbo RAT and is necessary for the Turbo RAT to sound right. The Turbo RAT also orginally used the LM308 op-amp not the OP07.
R14 was necessary for the status LED that was added to the RAT2 and Turbo RAT - known as the "RAT bypass LED" circuit and not shown in that project. It also necessitated the change from 1u to 10u for C13. When the RAT went to 3PDT bypass switching, those changes were reverted. They don't really affect the sound - so R14 is unnecessary and C13 should be left at 1u (unless you are adding the "RAT bypass LED" circuit).
R1 differences don't matter. R4 differences don't really matter either - but it affects the input impedance as does R5. So when both are used they should be 2.2M to match with using 1M R4 only.
I recommend you build an original RAT and add R5. Also add R12 and use 2.2M for R11 - this doesn't change the sound of the RAT or YDR, but without it it the Turbo RAT can sound farty and fizzy. Use LEDs for D2, D3 on the PCB, and put the 1N4148s and 1N34As on the switch. Note that 1N914 and 1N4148 diodes are the same.
This will give you accurate sound for all three variations.
See this RAT schematic for a clearer understanding.
