S. Whitt, Audio Compressor, in: Practical Electronics, January 1976 🇬🇧
Free online ressources on guitars, amps, effects, guitar technique and more. Dedicated to the fond memory of its founder SPeter Davidoff.
PDF:
Practical-Electronics-1976-01 Audio Compressor.pdf
(455.8 KiB) Downloaded 74 times
Ben N
Has thanked: 167 times
Been thanked: 50 times
Post by Ben N »
That looks too simple not to build.
mictester
Has thanked: 32 times
Been thanked: 825 times
Post by mictester »
Basically, it varies the working point of the transistor by moving its bias, thereby varying its gain. This was an approach used in some communications receivers in the 60's as a crude "audio AGC". It tends to introduce lots of distortion (it'll be a slightly squeezed fuzz sound), which doesn't matter too much in a communications receiver, but is simply NOT hi-fi enough for most purposes.
Other - slightly unusual - approaches to gain changing stages I've experimented with include using a "diode attenuator", where the current through a couple of diodes varies their dynamic impedance. This works well, and as long as your audio is only a few tens of millivolts, it works without significant distortion.
Other approaches include using ordinary bipolar transistors as voltage-controlled attenuators, using LDRs (as in the Really Cheap Compressor), using transconductance amplifiers (as in the Dynacomp), and using transconductance amps in the negative feedback loop of op-amps (my favourite method).
If you try the above circuit, don't be surprised if you get LOTS of distortion and noise!
