A Switching Scheme  [documentation]
mictester
Has thanked: 32 times
Been thanked: 825 times
Post by mictester »
mirtzbass wrote:hi! one question : can i use this system with a boss ds-1?? thanks
You can use it with any pedal that needs "true bypass".
Two things to remember - the relay MUST be the right type: TAKAMISAWA AL5WN-K and the switch MUST be a LATCHING type (unless you're going to drive it with logic).
mirtzbass
Post by mirtzbass »
many thanks man!!! if i have time i will make a pcb :)
sadrew
Been thanked: 14 times
Post by sadrew »
Hi mictester,
sorry I know you have specified the right relay type for your project...
but I can't find that AL5WN-K from my suppliers, so I'm trying to find a replacement.
do you think these ones instead could work?
http://www.schukat.com/schukat/pdf.nsf/ ... /S30EN.pdf
https://www.electronic-shop.lu/mechanis ... re=default
thanks
Cub
Has thanked: 97 times
Been thanked: 114 times
Post by Cub »
Get on this, lads. Proper loads of AL5WN-K relays ! [smilie=a_biggrin.gif]
mictester
Post by mictester »
sadrew wrote:Hi mictester,
thanks
Unfortunately, neither of these are BISTABLE LATCHING relays. A bistable relay has a mechanical locking mechanism that holds it in either the set or reset position even when the power is removed. That's why the switching circuit uses so little power - when you close the switch, the relay draws a little current as the capacitor charges and the contacts change over. While the switch remains closed, there is only a minute current passed through the high value resistor. When the switch is opened, the capacitor is discharged, the relay changes back, and obviously there's no current drawn from the battery because it's disconnected!
You can get the genuine Takamisawa AL5WN-K from many ebay sellers (that's where I get mine). I buy them by the hundred!
mictester
Post by mictester »
I was asked earlier for a PCB for this, so here it is.
Remember - It must be a LATCHING relay!
Here's the layout
Here's the layout
Here's the tracks!
Here's the tracks!
I frequently build them on Veroboard, too.
mictester
Post by mictester »
Cub wrote:Get on this, lads. Proper loads of AL5WN-K relays ! [smilie=a_biggrin.gif]
I buy them in 50s!
Just shop around for them - I get the two transistors, capacitor, diode, resistors and switch for much less than one of those nasty blue switches!
soggybag
Completed builds: Fuzz Face, Tone Bender, Big Muff, ICBM, Ugly Face, Green Ringer, Super Fuzz, Multiplex Echo, Multiplex Jr, Rebote, Echo Base, SHO, Fuzz Factory, Titan Boost/Octave, Easy Face, Tone Bender MkII, Trem Shifter, Zero Point Mini...
Has thanked: 28 times
Been thanked: 27 times
Post by soggybag »
What type of stomp switch do you use? Seems you still need a switch. The switching system might have some advantages but, I can't see price as a being a big factor. The blue 3PDT type switches are very cheap.
mictester
Post by mictester »
soggybag wrote:What type of stomp switch do you use? Seems you still need a switch. The switching system might have some advantages but, I can't see price as a being a big factor. The blue 3PDT type switches are very cheap.
Originally, I came up with this use of the relays so that I could use up all the SPDT switches that I'd removed over the years when converting pedals to "true bypass". I had a drawer full of them!
Nowadays, there are very good quality single pole push switches available for much less than the nasty TPDT footswitches. I use "vandal proof" stainless steel push buttons that are designed for outdoor use. The ones I use are latching ones, but momentary ones are available for use with CMOS logic. The switches are seemingly indestructible and completely waterproof!
Cub
Post by Cub »
I buy them in 50s!
All right, you win ! :mrgreen: I ordered enough to let the TriAxis and G-Major switch things in my rack and some more in case I mess up or want to mess about with them some more in the future.
roseblood11
Has thanked: 359 times
Been thanked: 312 times
Post by roseblood11 »
mictester wrote:
soggybag wrote:I use "vandal proof" stainless steel push buttons that are designed for outdoor use.
Which ones exactly? I couldn't find any vandal-proof switch that really works as a footswitch...
rrroo
Post by rrroo »
has anybody done a pcb layout for the momentary switch version?
mictester
Post by mictester »
rrroo wrote:has anybody done a pcb layout for the momentary switch version?
Yes - I have. I'll post it later.
rrroo
Post by rrroo »
great! thanks.
beardyman
Post by beardyman »
Thanks a lot for this circuit. I've installed it in my wah, using a slightly modified version of the layout on page 3, 2n3904/2n3906 and the original Carling SPDT. I didn't check the transistor pinout, and just copied the transistor outlines from the layout, and it didn't work at first, but I soon figured out that although the bce labels on the layout are correct, the outlines on the layout are the wrong way round (I hope this helps somebody!). I have also wired the switching contacts differently from the layout, to ground the input in bypass mode using what I think is a fairly standard scheme.
It works very well, except I am having a problem with a loud popping when the wah is switched on. Switching to bypass mode is silent. Using a Taiwan 3PDT wired in exactly the same way (as a DPDT) I have no popping at all through the amp. Not grounding the input in bypass mode makes no difference. A 2.2M resistor between fx input and ground makes no difference either - a resistor shouldn't be necessary on the output as it is referenced to ground through the pot.
So at this point I'm wondering what is causing the popping - it doesn't seem to be anything to do with the input or output caps building up a charge, as anti-popping resistors make no difference whatsoever, and it works just fine with a normal switch. It isn't the LED (there isn't one!). Could it be the magnetic field from the relay being picked up by the inductor (they're about 3 inches apart)? If so, how to cure it?
I'd really like to use this system as the Carling SPDT has a much nicer feel than the 3PDT in a wah, as it has a shorter travel before engaging and is mechanically quieter, but I'm scratching my head at the moment!
mictester
Post by mictester »
It might be the momentary change in current drawn when the relay engages (there's a small spike on the +9V line). Supply filtering is the answer here - put (perhaps) 100R in series with the +9V supply to the wah board, and put (say) 220µF at 16V across the wah PCB from +9V to ground. This should eliminate your switch-on pop.
beardyman
Post by beardyman »
Thanks for the swift reply! I will give it a try and report back!
beardyman
Post by beardyman »
I couldn't think of an easy way to implement the supply filtering on my existing board - I will probably install a dc jack just so I can hard wire the filtering components to it - but I tried connecting the relay board and switch to a separate battery to see if this was indeed the cause of the popping.
Well, it has cured the popping when the wah is switched on very effectively, so I guess adding some supply filtering should work too! However I am getting some popping through the speaker on switch off now. I suspect this may have been happening all along and I just didn't notice it because the switch on pop was so much louder. Anyway, it would be nice to get rid of this too, but it is much better now, so thanks for the advice!
cpm
Been thanked: 50 times
Post by cpm »
mictester wrote: Nowadays, there are very good quality single pole push switches available for much less than the nasty TPDT footswitches. I use "vandal proof" stainless steel push buttons that are designed for outdoor use. The ones I use are latching ones, but momentary ones are available for use with CMOS logic. The switches are seemingly indestructible and completely waterproof!
What kind of V-R swithces are suitable? Seems like all the ones i've seen dont look like would be easily operated as a "foot" switch
bubstance
Has thanked: 75 times
Been thanked: 116 times
Post by bubstance »
I'm curious about this as well. I can't find any reasonably priced latching vandal-proof switches.
