Page 5 of 14
Re: A Switching Scheme
Posted: 18 May 2012, 22:36
by bubstance
Just so it's there, here's a combination of mictester's circuit and a debounced bistable flip-flop using a 555.
**EDIT** I think the numbering on the relay is bunged up, but the concept is there.
Posted: 19 May 2012, 16:03
by jimosity
I'm also interested in a version that uses a momentary switch.
Specifically a layout of some sort (PCB, perf) or a schematic is cool too.
Posted: 19 May 2012, 21:06
by bubstance
The one above is for a momentary.
Posted: 20 May 2012, 16:30
by jimosity
Pinout on the AL5WNK should be:
1= + POSITIVE
2= NC1 (SEND)
3= COMMON1 (SEND)
4= NO1 (SEND)
5= NOT USED
6= NOT USED
7= NO2 (RETURN)
8= COMMON2 (RETURN)
9= NC2 (RETURN)
10= GND
I just made a custom library/part for Eagle, but I can't figure out how to move the name placement on the pinouts in the symbol view.
I tried leaving it as is with overlapping names on the symbol view; then though I could smash it in schematic view to move the pin names around, but that doesn't work.
Any ideas on how to do that? I'll then share the library for the part to make it easier for us.
Posted: 20 May 2012, 18:23
by bubstance
As far as I know the names of pins are fixed and cannot be moved.
Posted: 23 May 2012, 00:24
by jimosity
bubstance wrote:As far as I know the names of pins are fixed and cannot be moved.
This is what I'm talking about -- see how the names overlap...I can't figure out how to move those names apart a bit so they are legible.
In Symbol View
http://bandslink.com/share/cap1.JPG
And when you put it in a schematic
http://bandslink.com/share/cap2.JPG
Posted: 23 May 2012, 01:28
by bubstance
Yeah, like I said, I don't think those names can be moved unless you increase the width of the part. I made my relay symbol differently; it makes a bit more sense in my head than an 8 pin device and shows what's happening in the relay. Just use a relay symbol, like below, and then add in symbols for the switches to make a three part element. Then you can arrange it like above and keep the relay symbol separate from the switching elements.
If you want, of course.
Posted: 02 Jul 2012, 12:31
by rasta_maleek
mictester wrote:mictester wrote:You'll all know my hatred of the crappy TPDT and similar footswitches.
The circuit gives six big advantages:
1. Hermetically sealed gold contacts - clean and quiet switching.
2. Additional relays can be put in parallel with the first one. You might have to increase the 47µF to 100µF, but the switching will be entirely reliable.
3. Draws minute current - the whole of the battery power will be used to power your effect and the indicator LED!
4. Passes the "disconnected battery" "True Bypass" test.
5. Costs less than a good quality DPDT footswitch.
6. Allows simple connection of an indicator LED.
Remember - the relay MUST be a
Takamisawa AL5WN-K. Experiment (and a component shortage!) showed that the capacitor can be as small as 10µF (though it will stop working when the battery gets below about 8.5V) - my latest builds have used 47µF 16V tantalum beads (because I've got a boxful of them). I find that I still have plenty of the "Carling" SPDT footswitches that were pulled from old pedals to use up!
hi mictester
what sholud i do to use this circuit with a 5v/6v supply?
thanks a lot, this is a usefull solution to amp switching
Posted: 02 Jul 2012, 15:32
by adielricci
Here's my suggestion of an electronic switching scheme, with a simple flip-flop and bipolar transistors as audio switches, instead of FETs. The 2K2 resistor of the LED can be altered to 10K in the case of superbright ones.
http://www.handmades.com.br/forum/index ... 2422;image
It works.
Posted: 02 Jul 2012, 17:27
by Chugs
Cool, but the link requires a password.
Posted: 02 Jul 2012, 17:32
by jonasx26
adielricci wrote:Here's my suggestion of an electronic switching scheme ..
Can't see the schematic..
What are the advantages of using BJTs instead of FETs?
Seems to me that BJT switching would require very precise DC conditions and source/load-impedances to work properly.
Posted: 02 Jul 2012, 21:39
by adielricci
Sorry, I thought the link was open. The reason for using regular bipolar transistors was that FETs were not available easily in my country, and they were extremely sensitive to damage, not to mention much more expensive, at the time I designed this circuit, circa 1987.
https://img225.imageshack.us/img225/614 ... dielmo.png
Posted: 02 Jul 2012, 23:00
by mictester
rasta_maleek wrote:
hi mictester
what should i do to use this circuit with a 5v/6v supply?
Unfortunately you'll need 9V to make the circuit work - it'll work down to about 7.5V but no lower. You'll also have to increase the series capacitor slightly for reliable operation with lowered voltage.
Generating higher voltages from lower voltages is actually quite easy if you use simple switched-mode supply circuits.
Posted: 02 Jul 2012, 23:48
by jonasx26
Wow. That circuit could use some improvements..
Posted: 03 Jul 2012, 00:21
by adielricci
jonasx26 wrote:Wow. That circuit could use some improvements..
Be my guest!
It is the first idea, it worked fine, but I could polarize the transistors with a cleaner source, like a resistive divider with a capacitor, or something along that line.
My intention was to make it as simple as I could, keeping its functionality. Nowadays I prefer to use a 3PDT in my pedals, though.
Posted: 03 Jul 2012, 01:23
by jonasx26
I'd use op amp voltage followers and CMOS transmission gates in "current mode".
Check out 'Self on Audio' by Douglas Self. It has a great chapter on switching with FETs and CMOS muxes.
Solid state switching can be VERY good when done properly. Sadly, it rarely is. (in the world of stompboxes)
Posted: 03 Jul 2012, 11:23
by adielricci
jonasx26 wrote:I'd use op amp voltage followers and CMOS transmission gates in "current mode".
In which case, simplicity goes down the drain. Thank you for the tips, anyway. My proposal dies here.
Posted: 03 Jul 2012, 14:23
by The G
jimosity wrote:[...]
If you change the visibility from "both" or "pin" to "pad" it'll look like the left symbol:
- Symbols
- relay.png (2.44 KiB) Viewed 4877 times
Still, the block variant is not intuitive or easy to use.
You have a custom Eagle library attached, containing both variants. I used the datasheet, but mistakes are still possible. So check it before use.
Posted: 21 Jul 2012, 13:50
by Emanuele II
my eagle can't load that library..do you have any idea of why it does that??
Posted: 16 Oct 2012, 18:28
by deafbutpicky
I made some vero layouts for the momentary- and on/off foot-switch schematics, with the fx-in
grounded while in off state, as mandatory for some higain circuits.
Sorry for the kind of crosslinking, this isn't my "main forum", and musikding is where I keep all my stuff.
http://forum.musikding.de/cpg/displayim ... at=0&pos=0
http://forum.musikding.de/cpg/displayim ... at=0&pos=1
