Q.A. Rice, A Simple Compressor, Practical Electronics, February 1977 🇬🇧
Free online ressources on guitars, amps, effects, guitar technique and more. Dedicated to the fond memory of its founder SPeter Davidoff.
Ben N
Has thanked: 167 times
Been thanked: 50 times
Post by Ben N »
"Relatively insensitive pickups" were once my calling card, but that was a long time ago...
ppluis0
Has thanked: 121 times
Been thanked: 278 times
Post by ppluis0 »
IMHO, a small value resistor placed in series with the led would be good :roll:
Manfred
Has thanked: 1597 times
Been thanked: 1300 times
Post by Manfred »
I made this board layout considering the optinal series resistor before the LED as suggested by Ppluis0.
TR1 to TR3 could be BC548.
Ready-to-print PDF-files:
PE Simple Compessor PCB Component Side.pdf
(11.02 KiB) Downloaded 44 times
PE Simple Compessor PCB Solder Side.pdf
(2.71 KiB) Downloaded 45 times
Sprint-Layout6.0-file:
PE Simple Compressor.zip
(10.89 KiB) Downloaded 40 times
Manfred
Post by Manfred »
Board size: 1.7" x 1.1" , 43 x 28 mm
PE Simple Compressor 1 Vero.jpg (62.22 KiB) Viewed 799 times
PE Simple Compessor 2 Vero.jpg (63.26 KiB) Viewed 688 times
PE Simple Compressor Componet Designators.pdf
(213.82 KiB) Downloaded 40 times
PE Simple Compessor Component Values.pdf
(215.46 KiB) Downloaded 38 times
PE Simple Cut Pattern.pdf
(60.23 KiB) Downloaded 37 times
LochMaster 4.0 - file:
PE Simple Compressor Vero.zip
(262.31 KiB) Downloaded 35 times
bmxguitarsbmx
Has thanked: 657 times
Been thanked: 203 times
Post by bmxguitarsbmx »
I'd be tempted to take my output off the collector of TR2 for all that gain and distortion
ppluis0
Post by ppluis0 »
Hi Manfred,
According the schematic of a similar compressor posted at this link: viewtopic.php?t=31743 we can be sure that R7 value will be 470 ohms :mrgreen:
Manfred
Post by Manfred »
ppluis0 wrote: 19 Dec 2021, 02:21 Hi Manfred,
Hi Jose,
thanks for keeping an eye on it.
I did edit all the attached documents in my two posts above.
Manfred
Jarno
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Alembic F2B (tube preamp)
Opamp and FET buffers
Tables
Bookshelves
Basses
So many things! :D
Has thanked: 27 times
Been thanked: 75 times
Post by Jarno »
ppluis0 wrote: 14 Dec 2021, 00:52 IMHO, a small value resistor placed in series with the led would be good :roll:
Yes, but without it the LED goes Super Hard On :D
