Everyday-Electronics-1973-08 Waa Waa.pdf- (765.87 KiB) Downloaded 85 times
B.W. Terrell, Waa Waa, Everyday Electronics, August 1973 🇬🇧
- modman
- a d m i n
- Has thanked: 4287 times
- Been thanked: 2008 times
PDF:
- Jarno
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Alembic F2B (tube preamp)
Opamp and FET buffers
Tables
Bookshelves
Basses
- Has thanked: 27 times
- Been thanked: 75 times
Pretty nifty idea with the two levers, and cheaper/ easier to make than the rack and pinion solution often seen.
- Ben N
Sticking in a bridged-T like that, switchable, might make a cool mod for a fuzz face (being as that is what this is, pretty much).
- ppluis0
Hi Jarno,
Another easy way to rotate a wah potentiometer was implemented by Ernie Ball: one spring, a couple of bushings, several inches of wire and a little pulley at the pot shaft:
This solution, with a little experimentation, allows for a complete rotation of the potentiometer.
cheers,
Edit: this link describe the assembly of this mechanism: https://www.ifixit.com/Guide/Ernie+Ball ... ment/76294
- Jarno
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Tables
Bookshelves
Basses
I have an Ernie Ball volume pedal, so I am familiar with that mechanism, but with the rope and the spring, it might be a bit finicky to DIY this and get it right. Interesting assembly manual, might need to replace the cord on mine at some point in time (didn't buy the pedal new
