Devi Ever - Ruby, 90, Hounds Tooth
G.Bisson
Has thanked: 13 times
Been thanked: 57 times
Post by G.Bisson »
Drafted schematics of Devi Ever - Ruby, 90 and Hounds Tooth circuits using this old snippet from the Devi forums and following along with the written descriptions. That last line adds some confusion about the accuracy of this info.
Redrawn schematics. These haven't been verified in comparison to a traced pedal.
bmxguitarsbmx
Has thanked: 657 times
Been thanked: 203 times
Post by bmxguitarsbmx »
probably want to flip the 2n2907A as it is a PNP device. Pretty cool little octave/wavefolder block.
AZX309
Been thanked: 18 times
Post by AZX309 »
My hounds tooth trace. it actually says 05+DB+ on the inside which i find funny.
bmxguitarsbmx
Are you saying that the transistors are attached Collector to Collector, Base to Base, and Emitter to Emitter?
I would assume the PNP would be connected Emitter to NPN collector. But, I wouldn't want to assume.
Connected Emitter to Collector should give a crude octave/wavefolder effect. And sound gated.
Dr.Detroit
Has thanked: 19 times
Been thanked: 8 times
Post by Dr.Detroit »
bmxguitarsbmx wrote: 17 Jan 2022, 18:46 Are you saying that the transistors are attached Collector to Collector, Base to Base, and Emitter to Emitter?
The schematics in this thread correspond to the DE circuit building blocks that she has used for quite awhile. Not to say there's anything "wrong" with trying out a different transistor orientation, of course :thumbsup
287m
Has thanked: 472 times
Been thanked: 72 times
Post by 287m »
Devi circuit is the best practice to do if you want simple 1590A build. Did in perf, easy.
AZX309 wrote: 14 Jan 2022, 22:48 Image
followed, i do enjoy see your IG.
AZX309
Post by AZX309 »
287m wrote: 17 Jan 2022, 21:28
thank you much apricated!
...and this is exactly what it does! if you combine it with an extreme hi-end cut (see the Hyperion or SM) you can wind up with more of a pure octave.
