phasers with transistors
BMS1971
Has thanked: 42 times
Been thanked: 31 times
Post by BMS1971 »
Hello all
I used to own a EHX bad stone witch had only transistors (8?) and no IC. Sold it long ago....
It kept me wondering if they was a schematic of it somewhere and if other phasers where made like this with transistors and not ICs.
Benoit
OC26
Has thanked: 301 times
Post by OC26 »
Quick reply: Univibe
aionios
Been thanked: 369 times
Post by aionios »
The original Bad Stone used JFETs, not transistors. Many phasers like the Phase 90 and Boss PH-1 use the same method.
The only phaser I’m aware of that uses actual BJT transistors is the Pearl PH-44.
bumblebee
my favorite amplifier: ‘65 Twin Reverb
Completed builds: Fuzz, Distortion, Preamps….gain gain gain.
Has thanked: 207 times
Been thanked: 45 times
Post by bumblebee »
Korg Nu Vibe has about 28 transistors in it…could be FETS, I have no idea. Has some ICs in it but I’m not sure what they’re using them for. Some are for switching and slider pots wave shape formation, I know this much.
Sounds brilliant BTW. I bought the pedal when I found a new one far cheaper than retail.
I haven’t even opened mine to take a peak yet….been planing to just couldn’t be fckd. :mrgreen:
Also, the only bad stone phaser schematics I have use ICs.
If you can’t buy it, build it. If you can buy it, clone it.
bumblebee
Post by bumblebee »
Lani
my favorite amplifier: Bassman 5f6a
Completed builds: .....ummmm yeah. Too many to list.....
Has thanked: 107 times
Been thanked: 74 times
Post by Lani »
Wow.... This would be a chore to clone.
https://www.synthxl.com/wp-content/uplo ... Manual.pdf
JiM
Proco Rat
Hot Harmonics
Crackle Not OK
Has thanked: 69 times
Been thanked: 65 times
Post by JiM »
OFF-TOPIC
aionios wrote: 29 Jan 2022, 14:14 The original Bad Stone used JFETs, not transistors.
:secret: Just an off-topic remark : JFETs are transistors, that's what the T means.
It's not the first time i see people refer to only BJT as transistors, and it feels weird.
BTW, in the Bad Stone the 4009 is used as a MOS transistor array, half of the inverter gates are shorted. It's a nice way to have matching FETs.
aionios
Post by aionios »
JiM wrote: 30 Jan 2022, 13:29
OFF-TOPIC
Correct... but in practice, both in the DIY community and broader electronics field, 99% of the time you hear "transistor" it refers to BJT, and it's generally safe to assume this is the case. JFETs are always called JFETs and MOSFETs are always called MOSFETs, even though the "T" in both stands for transistor.
So if it feels weird, that means you're part of the 1% and you should give in and join us over here in the 99% :shred:
aionios
Post by aionios »
bumblebee wrote: 29 Jan 2022, 22:11 Also, the only bad stone phaser schematics I have use ICs.
The first version (most mummy face models) used JFETs and ran at 18V:
https://sites.google.com/a/davidmorrin. ... /bad-stone
Some very late mummy face models did use CMOS (e.g. the one here: http://www.home-wrecker.com/badstone.html) but they're pretty rare. It seems to have been right before the transition to the 3-knob V2, which all used CMOS.
bumblebee
Post by bumblebee »
Lani wrote: 30 Jan 2022, 13:19 Wow.... This would be a chore to clone.
And I thank you very much for the schematic! :mrgreen:
JiM
Proco Rat
Hot Harmonics
Crackle Not OK
Post by JiM »
OFF-TOPIC
aionios wrote: 30 Jan 2022, 20:38Correct... but in practice, both in the DIY community and broader electronics field, 99% of the time you hear "transistor" it refers to BJT, and it's generally safe to assume this is the case. JFETs are always called JFETs and MOSFETs are always called MOSFETs, even though the "T" in both stands for transistor.
Ideed, but you took it the other way around, implying that JFETs are NOT transistors, which is plain wrong.
Anyway, nothing of importance, case closed.
BMS1971
Post by BMS1971 »
Thanks everyone for your help
Ben
