Le HAUT-PARLEUR n°1754 - Juillet 1988 Distortion Booster.pdf- (2.12 MiB) Downloaded 72 times
Distorsion Booster, in: Haut Parleur, July 1988 🇫🇷
- modman
- a d m i n
- Has thanked: 4287 times
- Been thanked: 2008 times
PDF:
- phatt
Thanks Modman,
Interesting idea on the Kill switch instead of the common bypass as it only need a single pole switch.
The dry signal is always on and Distortion is mixed with it when engaged but I wonder if there is any loading of the pass signal?
Hum, I might have to test the circuit and see what I hear.
Phil.
Phil.
