Ken Willmott, Build a Guitar Preamp Distortion Box, in: Popular Electronics, August 1995 🇺🇸
Free online ressources on guitars, amps, effects, guitar technique and more. Dedicated to the fond memory of its founder SPeter Davidoff.
PDF:
PE-1995-08 distortion Box.pdf
(461.49 KiB) Downloaded 124 times
Manfred
Has thanked: 1597 times
Been thanked: 1300 times
Post by Manfred »
Ready-to-print PDF-files:
PE-1995-08 Distortion Box PCB Componet Side.pdf
(6.6 KiB) Downloaded 51 times
PE-1995-08 Distortion Box PCB Solder Side.pdf
(1.94 KiB) Downloaded 51 times
SprintLayout6.0-file:
PE-1995-08 distortion Box.zip
(7.12 KiB) Downloaded 44 times
ppluis0
Has thanked: 121 times
Been thanked: 278 times
Post by ppluis0 »
I swear I've seen in this forum a diagram of another pedal with this same topology, but I can't remember its name, nor in which section to find it...
Even the article had the oscillograms of the waveforms at different points of that circuit. :roll:
CheapPedalCollector
Has thanked: 432 times
Been thanked: 141 times
Post by CheapPedalCollector »
ppluis0 wrote: 24 Feb 2022, 02:53 I swear I've seen in this forum a diagram of another pedal with this same topology, but I can't remember its name, nor in which section to find it...
Reminds me of the differential distortion.
ppluis0
Post by ppluis0 »
You're right !!!
It's similar in concept to Dinosaural tube bender.
BMS1971
Has thanked: 42 times
Been thanked: 31 times
Post by BMS1971 »
CheapPedalCollector wrote: 24 Feb 2022, 10:06
actually it's exactly the same...
