diy "studio" compressor & eq question
tedsorvino
Has thanked: 26 times
Been thanked: 5 times
Post by tedsorvino »
Today at 11:12 AM
Add bookmark
#1
Hi everyone.
I'm quite experienced on building mainly guitar pedals and amps and now I would like to try my luck to the "studio" (semi) parametric eq and compressor world, for personal use. To start with I wouldn't like to try something expensive and very complicated.
So something like a good 3- 4 band (from around 100 to around 15k) parametric eq design with hi and lo pass filters (and maybe Q settings) is good enough for me. As far as compression goes I have worked with the THAT 4301 IC and I like it a lot for use with many instruments and vocals. Any good and tried optical, Vca or fet affordable designs are welcome.
Any ideas, pcb links and schematics for such designs are what I'm looking for. I wouldn't like to deal with overpriced kits etc. So designs with not complicated (3 d printing etc etc) housing would be ideal.
Thanks in advance
Jarno
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Alembic F2B (tube preamp)
Opamp and FET buffers
Tables
Bookshelves
Basses
So many things! :D
Has thanked: 27 times
Been thanked: 75 times
Post by Jarno »
Not sure about eq, but a solidstate la2a clone is a pretty straightforward project (so a la4 really), you can build it without transformers for even more lowcostness :)
See the groupdiy forum.
asbestosaurus
Has thanked: 48 times
Been thanked: 94 times
Post by asbestosaurus »
for a decent and fairly expandable EQ take a look at dylan's Core Shaper. easily found with a search here.
peterc
Has thanked: 68 times
Post by peterc »
GroupDIY has loads of projects, with people selling PCBs and great in-depth knowledge
https://groupdiy.com/forums/dynamic-processors.27/
https://groupdiy.com/forums/filters-equalizers.28/
Look for the 1176 projects for a FET-style compressor, and the Calrec EQ by Jakob Erlund is a world class EQ.
Enjoy!
