Low voltage tube overdrive
Vitallka
Been thanked: 65 times
Post by Vitallka »
Hi there. I am from Ukraine and I want to present you my project of low-voltage tube overdrive on a 6И1П (soviet analogue og ECH81).
Scheme:
https://app.box.com/s/flczcj62gqmv1n8jllnzcg4u3m00oj33
Sound is recocrding on a blackberry q10 (tube overdrive - tube SE - 1x12 Seventy80):
https://app.box.com/s/sr1b4yq1qk6x7evbz8wdh6cbdmudfqf3
Hope you are safe - thanks for an interesting design ;-)
Vitallka
Post by Vitallka »
There is no fighting in our area, but we thank you all for your support and sympathy.
I have made a similar scheme of fuses on lamps, but we still need to redraw the scheme. After a while I will share the scheme - you can use any pentodes of low power
ppluis0
Has thanked: 121 times
Been thanked: 278 times
Post by ppluis0 »
Hi Vitallka,
It's good to read that you're out limits of the most conflicting areas in your country. I hope that this nightmare ceases soon and the normal life can be reached again.
Regarding your design: perhaps many others dual tubes can be adapted to this same topology. EG.: ECF80, ECF801; 9A8; 6U8; 6CG8, etc.
Several types of triode/pentode manufactured for TV application are waiting an opportunity to bring out distorted sounds for us 8)
bmxguitarsbmx
Has thanked: 657 times
Been thanked: 203 times
Post by bmxguitarsbmx »
Vitallka,
Those are impressive tones. Has a really nice "gurgle" to the tone (if that makes sense). Are there tone controls on the "tube SE" amplifier that you are using to achieve the balance?
Best wishes to you and your people!
BMX
